Back fires @ 2100 after new motor, The chip is tunned dead on!
Old Aug 7, 2002 | 11:57 AM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
I have a back fire situation at about 2100rpm, before this and after this the motor runs great. Even when its backfiring the BLM is around 128. I checked for miss fireing plugs and wires. At first I thought maybe a VE cell was way out that wasn't it. I even tried leaning all the cells out at around 2000 rpm, but it still did it after. My accel inrichment didn't change anything either. My rotor and distributer are new. I'm thinking maybe the one injector on the passanger side of the motor, which doesn't get read by the O2 sensor is causing the problem. Does any body have any Ideas? I have a 747 ecm.
Old Aug 7, 2002 | 12:50 PM
JPrevost's Avatar
Car: 91 Red Sled
Give it more timing if it's backfiring through the intake manifold. This was a problem that took me a LONG time to figure out. Add 4 degrees to the cells around it and call me in the morning .
Old Aug 7, 2002 | 01:10 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
Thanks J, Makes sense because my new heads and intake have a totally different flow characteristic than the old stuff. I'll see if timing helps.
Old Aug 7, 2002 | 02:05 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
I added adout 3 deg from 2000 - 3000rpm, problem solved!
U the man J, Thanks for the help.
Old Aug 7, 2002 | 03:21 PM
87IROC350HO's Avatar
WoW....that's quick....Home of the Guru's
Stan
Old Aug 7, 2002 | 09:41 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
I just went thru the same crap on my friends T/A.
More AE (accel pump) will help also. His was too lean and given the engine combo needed a massive AE vs. MAP.
Old Aug 8, 2002 | 01:25 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
Thats weird, I had to decrease my AE by 1/3, to stop it from popping. My new motor, which probably has 90 more ponies than the old 300 horse motor, is less volumetricly effiecnt below 3200, so even the stock AE was just to much. But 3500 - 6500 she sucks back the gas now.
specialized
Jun 18, 2022 09:26 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
justin57
Aug 20, 2015 07:05 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
gwade12
Aug 8, 2015 08:17 AM
