Am I doing something wrong in WinALDL
Old Aug 8, 2002 | 11:13 PM
AlexJH's Avatar
Engine: 5.7L V8
I can't seem to get the BLM/INT/O2 tables to populate when I'm using WinALDL. Is there some trick to get it working?
Old Aug 9, 2002 | 12:24 AM
Morley's Avatar
Did you put a 10k ohm resistor across pins A&B?
Are you trying to power the cable using the laptop on battery power?
Old Aug 9, 2002 | 11:15 AM
AlexJH's Avatar
Engine: 5.7L V8
Yeah, I can see all the sensor data through winaldl, but the tab that has the BLM information is blank. I see a cell turn green depending on where my rpm/map is, but there isn't any text showing up.
Old Aug 9, 2002 | 11:28 AM
funstick's Avatar
try adding a 10ohm resitor or a 20 ohm resistor across pins a-b. also get yr laptop some power. alot of time the laptops will cut power to the serial ports when in battery use mode.
Fanatic1074
Oct 3, 2022 05:57 AM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
sheachopper
Jul 31, 2019 11:27 AM
Dyno Don
Jan 24, 2016 08:24 AM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
