crackle upon decel. how do I tune this out?
Car: 93 S10 blazer
Just got dual 2.5" exhaust with highflow cats but no mufflers.
when I let off the throttle it cackles and pops really loud.
My question is do I need to take timing out or fuel or both to stop this? Is that sound caused by excess fuel in the exhaust? Is this just a total lack of backpressure thats causing this?
Can I tune this away?
Car: 93 S10 blazer
too little timing?
I was thinking it was too much
I cant use the decel fuel cutoff because I just changed from the 730 to the 7747 and I have not had time to change the VSS. Looks like I need to take the tailshaft off to do it. In the mean time I was looking for a way to program the DFCO manually.
I will try to add some timing and take out some fuel.
I also just discovered that my header bolts are loose so that might help too.
THANKS
THANKS
