Cant get rid of massive knock retard
Old Sep 5, 2002 | 07:03 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
My friend and I are buring chips fo rmy 89 350 tpi tf heads and a 218/224 cam problem seems to be that from 0-60 i ge like no knock but downshifting in 3rd into 2nd the knock gets 31 degrees and retards the hell out of the timing meaning basically no power, car just screams. This does it with both stoch and madified chip. we have 30* degrees of timing total. how can i wipe all of that out? is something spiking somehting?
Old Sep 5, 2002 | 09:28 PM
funstick's Avatar
try adding some fuel and lowering teh amount of dcfo.
Old Sep 6, 2002 | 06:54 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Cant get rid of massive knock retard
Is this an auto? If so this seems to be a problem many have (others have asked about it here). I have seen the same thing in a 3.1L/auto f-body. Romp on the go pedal, trans downshifts and the knock counts go through the roof. Seems the best thing to do may be to increase the knock retard recovery rate. Can also try a lot more AE, it all depends upon whether the knock is real or not.
RBob.
the_hamturdler
Sep 30, 2015 12:50 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
Zell1luk
Sep 29, 2015 10:36 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
