383 and 165ecm
Old Oct 4, 2002 | 04:57 AM
e-man's Avatar
Car: 89 formula
Engine: 383
383 and 165ecm
I getting a 383 built and was wondering after reading some posts if its going to be a nightmare to tune with the 165ecm or should I swap to SD?Will 24lbs injectors be hitting 100% duty cycle or do I need 30lbs? The motor will have 10.3 cr,trickflow heads,GM hotcam (maybe a comp 306)and the stealth ram.
Old Oct 4, 2002 | 03:30 PM
Neil's Avatar
Car: '87+'02 Z28
Engine: 454 LSX
Transmission: T-56, Viper output shaft
Axle/Gears: Strage 12-bolt 3.73:1
No, it' s not too difficult to tune; however, it will take a little patience.
Old Oct 4, 2002 | 05:03 PM
e-man's Avatar
Car: 89 formula
Engine: 383
I have a question for you right now I have my 24lbs injectors set at 23.5 to get the blms at 128 on my old 350. How much lower should I drop them to for the 383? I dont want it going lean on the first start up.
Old Oct 4, 2002 | 05:39 PM
Neil's Avatar
Car: '87+'02 Z28
Engine: 454 LSX
When you fire your new engine up, make sure that you are not running rich. Keep your conditions on the leaner side if anything (not too lean though!). As you know i'm sure, a new motor with a rich condition will result in improper sealing of piston rings.
Got to go.
LT1Formula
Oct 8, 2015 08:34 PM
JSDaddy189
Sep 26, 2015 03:50 PM
