Blm Different Between Left And Right
Old Oct 7, 2002 | 09:36 AM
Robert Myers's Avatar
Car: 1968 chevelle, 1988 GTA
Engine: SB 355, 1993 350 LT1
Transmission: 4 speed muncie, 700r4
I have been recording large amounts of data using datamaster(approx. 30000 per drive) and was noticing that my blm on the right bank is always lower than my left. Ex: 127 left 119 right These numbers are after I average all the data for that drive. I have been changing my lower ve table and have had sucess but this trend seems to always be this way. I have averaged all my O2 reading but they seem to be fairly close. Ex: 555 left 552 right So far I have installed new O2 sensors and swapped injectors from left to right but the result is the same. I am running headers but the O2 bung is in the same location on both sides. I am running a 93 speed denisity ecm with stock cam and heads. The engine is a 93 lt1 in a 88 GTA. The only mods are headers, K&N open element, TPIS air foil, and TPIS afpr. I feel that with this condition I will never get to exactely 128/128. Is this something I should be concerned about?
Old Oct 9, 2002 | 05:18 PM
JPrevost's Avatar
Car: 91 Red Sled
A difference of 8 seems like a lot to me but I don't have any experience with the 93 LT1's. Have you tried just swapping the left o2 sensor for the right?
These aren't heated sensors are they?
Old Oct 10, 2002 | 07:04 AM
Yes, I have swapped the sensors and it is still the same readiing.
The sensors are not heated.
I still have my ccp on this engine. I am going to remove and plug the port. This line is on the right side of the engine but I would figure that the fuel vapor from the tank would be distributed equally in the intake. I am going to try it this weekend and see if it makes a difference.
Mark_ZZ3
May 24, 2018 01:02 PM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
gord327
Oct 3, 2015 01:25 PM
armybyrd
Sep 26, 2015 03:37 PM
