quick cable question
Old Oct 12, 2002 | 04:48 PM
SLOW91TA305's Avatar
I bought the ALDL to ECM cable for my 91 ta (730ecm). Will this cable also work on a 89 camaro (165ecm)?
Old Oct 12, 2002 | 06:26 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
No, a resistor needs to be in place to set MAF cars into diagnostic mode. My MAF cable works with SD systems tho.
Old Oct 12, 2002 | 09:26 PM
So I can just use this resistor and my cable will work? What is the value of this resistor and what pins do I need to jump?
FYI: I have the $65 cable from Steve Ruse
http://www.geocities.com/steve3034/cables.html
thanks
Old Oct 13, 2002 | 02:12 PM
A 10k resistor need to be put between A and B on the ALDL, you could prob put it behind the ALDL so it won't interfere with the cable, but don't leave it in, I noticed my car wanted to stall if I left my cable plugged in.
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
