383 TPI SC ECM 165 Tuning
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
Looks like your running lean with BLM in the 150s most of the time. If K_RETD is knock retard then you are getting some bad knock, retarding the timing 20deg at times, are you running ARAP?
Sanjay
Aug 12, 2015 03:41 PM
