Possible to program LG4 prom?
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Is it at all possible to program an LG4 ECM? The reason I ask is because I am using the stock LG4 ECM with my 400.
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
i believe it's not. i have asked before and the results were no. the ccc system is what i'm going to use on my 355. lets see what happens.
Car: 1988 GTA
Engine: 5.0 TPI
I wouldnt recommend it. While it does work fine with my 400, i am sure i am losing power due to using an LG4 fuel map and spark curve. Plus the quadrajunk carb is not my favorite...
Car: 1988 IROC-Z
i'll be using an 86 L69 PROM, Harness, & ECM. knock sensor woo-hoo. not an LG4:
. the q-jet isn't that bad... compared to that edelcrock performer
i had on there before.
i had on there before. Thread
