Is there a free Editor for the $32B (1227165) Chip?
Old Nov 3, 2002 | 12:15 PM
Wilson's Avatar
Im looking to make a few simple changes (idle RPM's & FAN's).
Anyone know of a program that will edit this bin?
$32B 1227165 87 - 88 Y & F CAR 5.0L / 5.7L TPI
Thanks!
Old Nov 3, 2002 | 07:05 PM
goneracin's Avatar
Winbin will edit the $32b file.
Old Nov 3, 2002 | 09:05 PM
Wilson's Avatar
Does anyone have the .ecu file for it? It doesn't come with Winbin. Thanks!
Old Nov 3, 2002 | 09:50 PM
funstick's Avatar
yes if you look at the DIY-EFI.org site in the FTP incoming section.
its there just keep scrolling down.
Old Nov 3, 2002 | 11:19 PM
Wilson's Avatar
Is it the $32BUA.ecu file? Cause everytime I try to open up a bin file in Winbin I get this error on my Windows 2000 machine:
"Run-time error '8002': Invalid Port Number
Am doing something wrong? I select the BIN file, then I select the $32BUA.ecu file. Then I hit the "Edit File". Right?
Old Nov 5, 2002 | 03:25 PM
goneracin's Avatar
I have to click "view file" button, let it open a small window, close that window, and then click "edit file". Dont know why. Also, i cant hav ANYTHING else open (internet, excell, etc) when workin with winbin. also dont know why. May also be a problem using it with win2000, nut sure. mine is on win98. Good luck
BTW, the .ecu file i use is 32Bv001.ecu. not sure if its better or worse then the buaecu tho.
Old Nov 6, 2002 | 08:03 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Winbin is funny like that. I had the same problem. if your ECU file sometimes doesnt correctly match a bit for whatever reason, you get that error.
You may also want to consider $6E. Somethings are better, some are not. But It is working for me until I go with a 730/749 setup.
-- Joe
Hotrodboba400
Dec 10, 2019 07:07 PM
Deemax
Sep 12, 2015 06:53 PM
Ranbo108
Sep 9, 2015 12:20 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
