Sanp-on MT2500 owner/users inside
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Since im awaiting my replacement laptops i have been utilizing my bro's snap on scanner and have a few questions if anyone knows.
The spark advance , from what i can tell its giving me the ecm additional advance, not including the initial advance of the engine. as far as i can tell i believe this to be true going by the load/rpm to what i have programmed, just without any other type of scan tool to back it up.
Also, is their anyway to change what is displayed on the screen?
possible to get your int/blm/map all into one viewabel frame?
i have all the manuals and have used it quite extensively but have never needed to juggle anything around (i know u can change what the led's are for) but i can find nothign if its even possible to change what the main display is..
thanks
later
jeremy
thanks
later
jeremy
Car: Devastating Droptop
Engine: 355 Supercharged
Transmission: Auto 4L60, Built for 700hp
I use the Snap-on ScanGrafix, which is software where you attach your laptop to the scanner and you can record and display all data in Graph or text form and arrange it any way you would like to.
While you are on the data display screen set the information you want to keep there on line two and press N to go back one screen and select "Fix Line 2" this will lock line two in position and allow you to scroll the other lines. You can do the same thing to line three "fix line 3" etc.....
KO1
16
Oct 15, 2015 05:00 PM
