ALDL cables?
Old Nov 18, 2002 | 03:23 AM
TurboTony's Avatar
ALDL cables?
Hey everyone, just have a few questions about building/buying an aldl cable.
I recently aquired my own laptop and want to get into logging and burning chips on my 7747 equipped truck. I downloaded and installed winaldl to the laptop and tried to use the cable from TTS powersystems that i have for my sy, but it didn't want to link.
Does anyone know if the datamaster cable will work with winaldl?
Also, if and when I build a cable, which one is better 1 or 2 transistors? What are each used for?
I did some searching around, seems that most guys use the one transistor cable, just figured i'd build the one that work best for everything, if thats at all possible.
I have done some searching around, just hopeing someone can fill me in.
Tony
Old Nov 18, 2002 | 04:36 AM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
The second transistor in the two transistor interface is for data going from the laptop to the ECM. Older ECM's (7747 included) only use one-way communication so the extra transistor is not needed.
Old Nov 20, 2002 | 08:09 PM
primo's Avatar
Will the one transistor cable work with data master on a165 ECM.
And where can I get an ALDL Molded connector?
Old Nov 21, 2002 | 03:01 PM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
160 baud will work with one transistor on the 165.
To use 8192 baud you need two transistors.
I don't know what data-master uses but probably 8192 baud.
Old Nov 22, 2002 | 12:28 AM
TurboTony's Avatar
Has anyone tried running a 2 transistor 8192 buad cable with the 160 baud ecm? Will it work?
Tony
Old Nov 22, 2002 | 06:43 PM
Bluevette85's Avatar
Car: 85 Corvette
Engine: 355 Superram
Transmission: 700R4 Transgo Shift Kit
You can use a two transistor cable with the 160baud ecm but communication will only be one way and slow.
Old Nov 23, 2002 | 09:54 AM
primo's Avatar
Do yoy know a sourse for the ALDL Molded connector to connect to the ECM?
Thanks,
Old Nov 23, 2002 | 06:01 PM
JPrevost's Avatar
Car: 91 Red Sled
Autoxray sells em for like $25. Since their hand held unit plugs into GM, Ford, and Chrysler they have interchangable cords. I don't know the part number but call up Summit, they've got it.
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
