False Knock and Knock Attack Rate
Old Nov 23, 2002 | 05:19 PM
justme's Avatar
I am getting some knock retard at idle because of the noisy valvetrain. I don't want to try to the teflon tape on the knock sensor because I really don't want to decrease its efficiency. Am I correct in thinking I could change the knock attack rate in Tunercat to 0 under 1200 RPM so it won't retard at anything less than that or would this be a mistake?
Old Nov 25, 2002 | 06:30 PM
funstick's Avatar
you could zero the amount of knock retard at 1200rpm and under.
just make sure you dont drive up a hill luuging the engine using 86 octane fuel with a big heavy trailer on a 115F degree day. i think youll be ok otherwise. but then agian whats so nosiy with the valve trian ?? lash to loose or a big mechanical roller cam and double roller chain or gear drive ? maybed you could hush up the valve train. better to have knock protection then not have it. where are you getting knock at idle only ?
Old Nov 25, 2002 | 09:46 PM
justme's Avatar
Has a fair size solid roller, and double roller timing chain. Also Crower recommends lash to be set at .026 & .028 which seems a lttle loose. If I give it a little gas to bump the idle up the knock goes away. I had emailed Ed Wright a while back and he told me the solid roller would drive the knock sensor crazy. I figured since the car has a 3500 RPM stall in it it couldn't do anything really below 1200 RPM anyway.
Old Nov 25, 2002 | 11:04 PM
funstick's Avatar
hmm yeah i would say go ahead and pull the knock reatdr amount under 1200rpm. or you could bump the idle just a bit. that never good for the lumpty lumpty sound though.but be careful listen for real knock.
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
LT1Formula
Oct 8, 2015 08:34 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
efiguy
Sep 27, 2015 01:30 PM
