Any reason I should leave the BLM update amount at 2?
Old Dec 18, 2002 | 03:50 PM
2QUIK6's Avatar
Car: 89 Turbo Trans Am and lots of non-3rd gens
Engine: 231 SFI Turbo's, LT4, LT1
Transmission: 2004r, 4L60E
Any reason I should leave the BLM update amount set to the factory 2 in the TPI $8D? Which means the BLMs can only increment or decrement 2 units at a time, from 128 to 126 or 130...
Why not set it to '1' so it can go from 128 to 127 or 129 for finer fueling adjustments??
Old Dec 18, 2002 | 11:35 PM
funstick's Avatar
are we sure thats not blm update intervals IE 2 seconds ?alot of the later p4 code ive noticed use a 2 or so second updates for blm and pushes alot of fuel trim correction of to the intergrator. which editor are you using ?
Old Dec 19, 2002 | 12:55 AM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
My BLM is at 129 at idle so mine will move in increments of one. So if it is seconds, why not have it update every second?
Old Dec 19, 2002 | 12:52 PM
2QUIK6's Avatar
No, its BLM increments as I never see BLMs of say 127, 125, or 129, 131, always increments of 2 from 128.
I set the value to 1, now I see 127, 129, etc..
carid
Sponsored Vendors
Sep 10, 2015 09:33 AM
Wylecoyote08
Sep 8, 2015 08:26 AM
TheExaminer
Sep 7, 2015 08:34 AM
rsrookie
Sep 5, 2015 07:08 PM
