Cant program, help me out will ya
Old Dec 26, 2002 | 06:24 PM
iwantazed's Avatar
I am having problems burn to a chip. I have my programmer hooked up to a win 2k station I can copy the chip down save it as a bin. I Then remove Vats from the system, save the file and bring it back into the programmer software.
Sounds good so far, right?
Wrong, I take a freshly cleaned chip and slap it into the programmer, blank check to ensure its blank. Then go to program the device. About a split second later the programmer dings and says error programming. I read the chip and it has like the first two hex's programmed and nothing else.
I have tryed rebooting and closing all programs with no luck. Its the same story over and over again.
I am going to try it on a different computer next. I searched and found that a few people were having the same problem as me. If anyone knows how to fix this or has any ideas, Post away!!!
Old Dec 27, 2002 | 07:12 AM
kevinc's Avatar
Car: 1982 Z28
Make sure your programmer's software is configured for *exactly* the PROM type you're burning. Programming voltages vary widely by chip type...27C128 versus 27128A for example. Both 128K chips, but program at different voltages.
Old Dec 30, 2002 | 04:22 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
not much detail on your hardware.
what blanks? what programmer? what ecm is it for?
does your programmer have a compatible software that would work in dos (by utilizing a boot floppy) that youv'e tried?
djmarch
May 8, 2016 11:32 AM
ULTM8Z
Oct 2, 2015 01:25 PM
bryanwood74
Sep 24, 2015 09:50 PM
f-bodyz28
Sep 2, 2015 05:03 PM
bdads
Aug 24, 2015 06:01 PM
