Turbo code for an '808?
Old Jan 16, 2003 | 08:32 PM
JohnL's Avatar
I have an Australian '808 that I'd like to use on a 4 cylinder turbo. I've had a look around, but I can't find a BIN for this ECM that has MAPs over 100 kPa. Any suggestions?
John
Old Jan 17, 2003 | 08:03 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Kalmaker.com
or some such thing.
thou they have been in and out of business, and at one time just left their customers hanging. They did a boosed mode 808 at one time.
Or get into the code and read up on the 749 way of doing things, and patch the two together.
Old Jan 17, 2003 | 09:48 PM
Balael6's Avatar
Car: 1988 Formula
Engine: Twin Turbo .60/.63 305
Transmission: T-5 5 speed
Don't know if this helps or not but...
The quad 4's in 88 use the 749 ecm. It has the capabilities to handle boost as previously mentioned. I am setting up the 749 to run a boosted TT setup in my firebird, and it has a setting for 4 cylinder's in the code.... so i don't see why it wouldn't work if you got the harness, and sensors and such from a quad 4.
My 2 cents.
pj
Old Jan 18, 2003 | 11:18 PM
JohnL's Avatar
Grumpy: Thanks for the response. The bloke now marketing Kalmaker in Western Australia (Alan Gibbs) is very helpful, and as you say, can supply a turbo Kalmaker system. But you still need an eprom burner and to use the Kalmaker in more than 1 car, you need to buy another "security pal" which costs 40% of K's real time board system (still probably good value though). I've had a look at what you fellas are doing and it looks interesting enough to have a go at some elementary NA ECM modifications. I might still go for a Kalmaker after playing with PROM burning. As for code splicing from the 749, that sounds like trying to run before I can crawl. By the way, www.kalmaker.com.au, and there are also links to a Forum54 BB.
Balael6: Thanks also for the response. What's a "quad 4"? Adapting a whole 749 sounds like it might fit my crawling pace. Where do you get them from in the US, how many $ roughly, and are they similar to a '165 (which is what our '808's are based on).
John
Old Jan 19, 2003 | 07:21 AM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
http://www.speedtoys.com/~bort62/7749/Main.htm
Heres all the info regarding a 165(808) to 749 swap. BW
Old Jan 20, 2003 | 01:57 AM
JohnL's Avatar
Saturn5- thanks for the great link! I see you had some input to the project as well. This is a neat way to get the solution I'm after.
Does anyone have any links to US sites that might sell the Sy/Ty 749 stuff used and freight it to the land of Oz?
Thanks again,
John
BumpaD82
Feb 26, 2016 02:57 PM
Reese-J
Sep 14, 2015 02:43 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
64Chief
Sep 12, 2015 08:05 AM
