Knock sensor retrofit
Old Jan 18, 2003 | 01:13 PM
yellow73bb's Avatar
I bought a couple of knock sensors at the junk yard today, and want to put one on my engine. I already have the amplifier module hooked in, with the blue wire ready to hook to. I am using th 1227747 ECM.
I noticed that when I removed the knock sensor from the 350 at the junk yard, it was screwed into the water jacket on the block. Is it necessary that it be in the water jacket (sound conduction through water or something)? Or can I just run it into any threaded hole in the block and have it work.
I presume that it should work as well on a 454 as on a 350.
Anyone have experience with this?
Thanks,
John.
Old Jan 19, 2003 | 01:56 AM
Morley's Avatar
Re: Knock sensor retrofit
John.
Don't presume too much, the knock sensors are "tuned" for a particular engine's wall thickness. Thats why there is a different P/N for 305's & 350's.
And yes, I do believe it needs to be installed into a water jacket, again part of the tuning done when they are made.
Old Jan 19, 2003 | 08:44 AM
yellow73bb's Avatar
I guess I will check to see if there is one for the 454. Perhaps one from a Gen 5 or 6 might work on mine. Might be worth trying.
Thanks.
Old Jan 19, 2003 | 02:54 PM
Morley's Avatar
Thanks.
check the 454 truck applications.
L98GTA87
Oct 19, 2015 10:43 PM
cking99
Sep 22, 2015 11:33 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
