How do I convert MAF voltage to counts?
Old Jan 20, 2003 | 12:08 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I am going to start to re-calibrate my MAF flow tables on my MAF car.
I did a scan using a AutoXray and item #24 read 1.78V, next item was 8gr/sec. The engine was running at idle.
The MAF tables are counts vs flow rate. So how do we convert MAF voltage to counts.
I wish that the scanner gave me the MAF counts instead of the voltage because then I would know exactly where to go in the MAF tables for my changes.
Old Jan 20, 2003 | 03:18 PM
funstick's Avatar
i posted a maf flow chart a while back it has voltage vs counts.
search maf flow
Old Jan 20, 2003 | 05:41 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
I found your chart.
If the MAP volts that I scanned is correct, 1.78V with 8gms/sec flow, your chart is no where near my actual case.
In my MAF table 192 counts is associated with 6.2 gms/sec, and
256 counts is associated with 8.6 gms/sec.
One line of your chart is 8.sgms/sec,,,256 counts,,,,0.73V
Anyway, what is the 1.78V that I scanned today????
The car was at idle, closed loop, learned angeaged, MAF flow 8gm/sec, engine @ 1190 RPM, MAP volts 1.78V.
Now I have a MAF car, but the AutoXray header for item #24 is MAP sensor.
So whats going on.
Old Jan 20, 2003 | 09:23 PM
funstick's Avatar
im not sure but maybe the autoxray isnt accurate. did you try the moates software. ??? anyways it has the Vout=counts scales in it. thats what you asked for thats all i had. sorry DOC.
Nick McCardle
Sep 10, 2015 08:36 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
RyanJB
Sep 2, 2015 01:27 PM
