a possible arap starting problem fix?
Old Jan 28, 2003 | 03:54 AM
badgta's Avatar
Car: 1991 FORMULA
Engine: ZZ4 + LT4 HT CAM 430HP
Transmission: 700-R4 COMING T56
Axle/Gears: 9" 4.56's (COMING)
i had a modified arap bin that i did burn for me recently till i got my pp... for some reason it takes about 3-sec of cranking to start...
i did a search here a found a interesting thread...
the topic was a fix to arap starting probs people were expereincing a crank time like i have.... the fix to this was to mod a bin named "crank fuel pw multiplier vs ref pulses (1-16)"
it seems that if i change all the 0's in the 1-8 to .5 for 1-4 and .25 for 4-8 that i can easily cure this problem, if there any drawbacks or cautions you might have before i try this? is it a bad idea or a good idea?
thanks
adam
Old Jan 29, 2003 | 12:36 AM
drive it's Avatar
It works great-however if you find you have "hot soak" hard restart problems, then you'll need to back off on those values to hit a balance.
92camaroJoe
Jul 29, 2023 07:57 PM
theshackle
Mar 5, 2017 06:37 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
92camaroJoe
Aug 13, 2015 06:07 AM
