aah....so many bins!!! where to start?
I just got into prom burning and have found a bin that runs ok but how do I know where to start I know they sey to start slow with flags and move up from there but I don't know where to start with my setup it is a 350 TPI with 64cc heads flat top pistons cam is quite big with 112* lobe seperation and pulls about 12-13 in mercury I have 58mm TB large tube runners with eddelbrock base 30# injectors doug thourly headers and duel 2 1/2" exhaust and a paxton pushing 5-7 Lbs of boost so as you can see starting with a stalk chip I can almost get up to 50 mph but that just dosen't quite do it for me
any help would be greatly appriciated
Thanks in advance
Thanks in advance
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
I'm in the same situation.......So I cant tell you what to do.....But my plans are.
- Start with change inj.const. to #30 and get the car running.
- Trim fuel and ignition on a dyno (hopefully with a romulator)
- Then add boost...........and let the FMU and boost retard handle it.......
sorry if I couldnt help you....
