Mysterious code 42 ?!?!
Old Mar 14, 2003 | 03:03 AM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
So I'm out cruisin having a good ole time. While I'm going around a cloverleaf on the highway the engine bogs real hard and the SES light comes on (7747 here).
So I click to the Error Codes tab on WinALDL and the only code in there is code 42 EST. WTF?
I've had the battery disconnected since the last time I set the timing so I'm sure that it was this occurance that set the light off.
After the code was set, the light stayed on and the engine continued to run badly...like there was no SA.
I pulled over and shut the engine down. Waited a sec, and fired it back up. The SES light was off and everything ran like before. I guess once the code was set the ECM stopped using the SA tables in the PROM.
I got this from my ARJU hack...
Code:
        ; ERROR 42
        ; EST MONITOR
LD546   FCB  4  	; 450 RPM limit,
LD547   FCB  0  	; Num PA1 cnt's for error
LD548   FCB  4  	; Num of EST faults for 42A
LD549   FCB  4  	; Num of EST faults for 42B
I get the 450 rpm limit but after that the rest means nothing to me.
Maybe I need to check the EST connector?
Old Mar 14, 2003 | 08:09 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Try another chip.
Yes, the actual prom.
I've seen 747s, and 148s pop a 42 intermittently.
Actually 4 times.
I think on the 747 I also disabled the 42 flag.
Old Mar 14, 2003 | 12:40 PM
Car: Bee-Bowdy
Axle/Gears: fo-tins
I'll do that.
I know some of the junkyard chips I have will erase and program fine...but sometimes they will throw a code 51. The chip "looses contact" with the ECM...that's no fun in traffic.
Old Mar 14, 2003 | 03:34 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Originally posted by V8Astro Captain
I'll do that.
I gave up using junkyard chips for that and the sometimes hassle of getting them to erase.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
Gordonr1973
Sep 29, 2015 11:59 AM
