Question for Grumpy
Old Mar 28, 2003 | 03:52 AM
YenkoZ28's Avatar
Car: 1991 Z28
Engine: 305 TPI under 14 psi
Transmission: aftermarket T56
Axle/Gears: Moser 12 bolt 3.08 gears
Question for Grumpy
How is the base pulse constant figured out for table F28A on the $58 mask? I know it is a function of cylinder volume and injector size, but could you go through an example on how to figure the constant? I've searched the forums on diy-efi and syty.net with no luck.
Old Mar 29, 2003 | 02:42 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
BPC = 1461.5 * (VOL / RATE)
VOL = Vol of 1 Cylinder in liters
RATE = Injector flow in gms/sec
gms/sec = (lbs/hr / 3600) * 453.6
It looks like this might be the one.
The info I have on that mask isn't complete.
Old Mar 29, 2003 | 06:16 PM
YenkoZ28's Avatar
Car: 1991 Z28
Ok thanks for the great answer. I figured you'd be the one to ask on such things
Old Mar 29, 2003 | 07:30 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
**Usually** if you look at similiar hacs to what your working on you can spot simulairities, ie a Speed Density is a speed density. So some of the stuff kind of lines up from say a TBI to a SD port. The code is somewhat a series of patches and they often repeat themselves from one mask to another.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
