Needham EMP21 programmer
Old Apr 10, 2003 | 10:35 AM
LT1Formula's Avatar
I came across a Needham EMP21 programmer and wondered if anyone out there is familiar with setting it up(drivers etc). I downloaded the software from Needhams, but I don't know if I need anything else. Bill
Old Apr 10, 2003 | 02:20 PM
yellow73bb's Avatar
I have an EMP30, and it works great (I am using XP). Just run the install, hook it to your parallel port and it should go. It probably won't work with a USB printer port though, it wants actual hardware to write to.
Old Apr 12, 2003 | 01:42 PM
SIMON HOLTBY's Avatar
I use an EMP 20 without problems. I think the 21 is a newer version that connects to the USB port, you can check on their website. I use their dos software.
Programming procedure is
Connect to computer
fit correct 'family module' 01A in most cases
run software and it will connect to programmer
select device eg atmel 29c256 (it says what family module to fit)
enter your bin file name and location
click on 'load file'
click on 'buffer editor' if you want to check if bin has loaded
click on 'program device'
Simon
Old Apr 13, 2003 | 12:37 AM
vanceh's Avatar
I'm using a EMP-20 programmer, it's also older then your 21 but this is a very good machine. I think it sold around $400 when new. The EMP-20 is restricted to Windows 95 or 98 and runs in a DOS window, no big deal. When buring 29C256's I used family module 01A, burning 29F040's I used module 22A.
You have a good machine, hold on to it. Wish I had the newer model.
Old Apr 13, 2003 | 10:14 AM
LT1Formula's Avatar
Thanks for the replies, and information. I am anxious to get started programming. Bill
Eric2ndGen
Nov 5, 2015 01:51 PM
-=Z28=-
Sep 24, 2015 10:21 AM
f-bodyz28
Sep 2, 2015 05:03 PM
Lionsden
Jul 22, 2001 06:52 PM
mick
Apr 11, 2001 12:54 PM
