Getting back lost torque after TPI to LT1 Intake
Old Apr 25, 2003 | 12:09 PM
S10Wildside's Avatar
What sort of changes need to be made to the prom (730 ECM) to get back some of the lost torque after converting to the LT1 intake? Some have said it is not true that the LT1 intake robs low end torque compared to the TPI setup. I can testify that there is a noticable loss in low end torque. I've got my VE tables very close and I've played with the spark advance a little (up to a few degrees advanced). Any recommendations from here?
Old Apr 25, 2003 | 01:25 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Getting back lost torque after TPI to LT1 Intake
All of engine design is compromises. When you change intakes and get better top end, you will lose some bottom end.
You probably dropped a little in mechanical VE at the lower speeds so you might try taking a little fuel out, and then taking out a little timing.
Old Apr 25, 2003 | 11:10 PM
Thanks, I'll definitely try that out.
midge54
Dec 27, 2019 04:14 PM
Fast355
Dec 2, 2016 06:33 PM
fonzie85
Aug 13, 2015 11:50 AM
Sanjay
Aug 12, 2015 03:41 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
