APYP Questions
Old May 3, 2003 | 03:22 PM
Sena'sIROC's Avatar
APYP Questions
Real quick guys:
1) Is the ALDS SA the base timing or is the Spark Reference Angle - Base Timing the one I want to change to set the base timing in the PROM? (I want to set the base timing in the chip to 8.09 degrees)
2) What is the Oil Temp flag that needs to be turned off? I don't know the option code of it.
3) This PROM is for a Manual Tranny therefore shouldn't the ManT? flag be checked?
Thanks for all the support.
Brian P
Old May 4, 2003 | 02:54 PM
Sena'sIROC's Avatar
Anyone??
Thanks,
Brian P
Old May 5, 2003 | 07:08 PM
Sena'sIROC's Avatar
noone??
Old May 5, 2003 | 10:23 PM
Ragtop89's Avatar
PM your APYP questions to Anetheses.
He should be able to help.
A APYP search might turn up some answers.
Anetheses has a "hot" and a "cold" APYP that I DLed off of his sight.
They're both set-up for use in a '89 MAF 3rdGen.
I believe the "hot" bin uses the stock timing for an '89 Corvette running aluminum heads - dont take my word for it though!
I'm pretty new at this DIY PROM stuff . . .
I hope that helps!
Old May 7, 2003 | 08:18 AM
FstBrd6point3's Avatar
i dont think you would want to set yer spark reference angle at 8.09, that value is suposed to be equal to what you have your base timing set at mechanicaly, so break out the timing light, set yer timing to 8.0 and then put 8.0 in the chip.
Old May 7, 2003 | 06:07 PM
Sena'sIROC's Avatar
I appreciate the help fellas.
FstBrd6point3:
In the PROM the closest I can get to 8* is 8.09 degrees. The next value down is 7.73 degrees. The margin of error is greater in the latter as compared to the actual static timing.
Thank you,
Brian P
MustangBeater20
Oct 29, 2022 09:20 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
dyeager535
Aug 28, 2015 08:10 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
