SES light won't go away!
Old May 8, 2003 | 01:27 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
I just got my car back together for the summer. When I turn the key to the on position my SES light comes on and stays lit and the primary fan comes on.
I tried a code scan, the SES light just stay lit
I did a 730 conversion last summer and drove it for a few months on SD.
This is what I have tried to fix it:
1) Tried new different memcal
2) Reprogram chip like 3 times
3) Tried different 730 ECU I know is good b/c it works on another car.
I know a bad chip or memcal or the chip in backwards will cause the SES light to stay on but what else will cause this?
My Setup: 89 IROC converted to 730, using Craig Moates memcal adapter, and PP2
Old May 8, 2003 | 02:17 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
When I turn the key to the on position the SES light will sometimes pulse. It will never fully turn off just get brighter then dimmer and keep doing that.
Old May 8, 2003 | 03:26 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
I am so confused. When I face the notch in the EEPROM toward the center of the mem-cal the SES light doesn't come on (still doesn't start). When the PROM is facing toward the outside of the ECM case the SES light comes one.
Isn't the proper way with the notch facing the edge of the ECM case?????
Old May 8, 2003 | 03:27 PM
grumpyx's Avatar
zif socket is loose/bad,maybe.I do know when you have things right th ses wil flash on then off once with the key on,engine off.
Old May 8, 2003 | 06:54 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Okay I downloaded a new bin online, didn't change any values just programmed it to a chip and put it in my car.
With the key on the on position the SES light stays lit BUT the fan is not on now. I did a code scan and got code 12 and 15 (Low temperature indicated at engine coolant temp. sensor)
I cleared the codes and the SES light still stays lit with the key in the on position, the only code I get now when I check the codes is 12.
Old May 9, 2003 | 03:04 AM
Morley's Avatar
Ok, so now you have the code 12 engine off key on? Will it start? And yes, in Craig's adaptor the notch on the chip faces AWAY from the zif handle and towards the edge of the ECM.
Make sure the adaptor is fully seated in the ECM too. also, if you have another chip you may want to try it, if not see about getting one, might have a bad chip.
Old May 9, 2003 | 04:28 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Finally fixed it all. I was having a starting problem which was my starter so I couldn't fully test the chip, fixed that. I fixed the limp home problem. The 2 chips I tried were bad. I burned a new one and it works great.
So anyone who can’t get the thing out of limp home mode, keep trying new chips…
The SES light does stay on with the key in the on position is this normal? I haven’t driven my car in almost a year so I forget.
Old May 9, 2003 | 09:03 PM
Morley's Avatar
The SES light does stay on with the key in the on position is this normal? .
Yes, key on engine off the light should stay on.
eightsixseven
Dec 16, 2024 01:50 PM
Jk_Under
Sep 2, 2015 10:59 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
Omega
Aug 10, 2015 12:46 PM
