O.K., I've got a specific question finally
Old May 12, 2003 | 02:45 PM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
Using GMECMEdit on an 86 TPI bin ($32) and 32bv001.ecu, I have a question about the flags that can turn on and off. The VATS, MAF, EGR fields are easy enough to know what's going on (checked on, blank off)... but what are the "b0, b1, b2, etc" values that come up?
Old May 12, 2003 | 04:02 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
These are "default" labels for each field. They stand for bit 1, bit 2, etc ... If they are unlabeled like this, it means the person who created the ECU file didn't really know what they were for, or they are unimportant. You can consult a hac of the bin to find out what they're for (if known).
The way a flag (or "bitmask" as they're actually called) works is this:
you have a single byte (in the case of our 3rdgens). 1 byte = 8 bits (eg 10010101).
This means you have 8 "flags" per byte. the 0th bit is all the way to the right, the 7th bit is all the way to the left. when a flag is checked, the bit in the corresponding position within the byte is set to 1. unchecked, the bit is 0.
so 0x00 (binary 00000000) would have no flags checked. 0x01 would have the 0th bit checked (00000001), and 0xFF would have all bits checked (11111111). Hope this helps.
M
Old May 12, 2003 | 04:35 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
A good rule of thumb is, if you don't know what it's for, you shouldn't touch it. You might accidentally hit the 'war games' bit and your ECM might unleash global thermonuclear war instead of running the car.
Old May 12, 2003 | 04:37 PM
Mangus's Avatar
Transmission: T5WC
or, if you have an extra powerful ECM, it might launch global thermonuclear war WHILE running the car.
Old May 13, 2003 | 11:30 AM
bnoon's Avatar
Would you like to play a game?
Thanks guys. That was an easy one, being in binary relates directly to my job in the telecom field. Now, to move on to burn number two...
Frozer!!!
Jan 19, 2024 04:55 PM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
aaron7
Aug 17, 2016 06:02 PM
Polo Z03
Sep 10, 2015 06:43 PM
redmaroz
Aug 16, 2015 11:40 PM
