Everybody is speaking greek to me!!!
Old May 31, 2003 | 04:27 AM
86irocss's Avatar
O.K. for starters. I have an 89 IROC 5.7 TPI. Now I've looked over alot of these posts and all I see is everyone speaking greek ( i.e. WOT,PE,AFR...ect)
Please help this 32 year old back-yard mechanic undersand this terminology?
Where can I pick up the stuff to re-program a chip? And where can I get blank chips?
Reading some of the posts, I see that almost everyone has gotten rid of the 350 motor for something else. Is there somethig wrong with the 350? Or can I get some good HP's from it, for I don't have the money for a bigger RAT Motor.
I recently read in GM High-Tech Performance that I could get 414 HP (333 RWHP) by switching to a Holly Stealth Ram set up. Should that be a way to go?
Everyone is well knowleged in all of this, I don't do to bad on things but when in comes to dealing with the car's computer, I'm an idiot!! I need all the help I can get!
Someone....anyone, Please make me smart in this aspect of the Fuel Injected Car.
Signed
Hoping someday Carb's will be King again....LOL
Matthew
Old May 31, 2003 | 05:02 AM
86irocss's Avatar
O.K. before I get booted out for not checking. I found the article by Trax about re-programing the PROM. But I know I'll have some questions after I print it out and read it.
Please, Don't be mad at me, I'm still learning.
Matthew
Old May 31, 2003 | 05:08 AM
JohnL's Avatar
There's a Greek Dictionary here
John
Old May 31, 2003 | 05:52 AM
86irocss's Avatar
If Trax is reading this:
Do you have a part 2 on your reprograming article?
Old May 31, 2003 | 06:38 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Everybody is speaking greek to me!!!
Nope, your on your own, pal LOL
Like any tech talk, or foreign language it'll come to you, lots of the terms start to make sense after just a little while.
Xtronics has a proven track record of supplying programmers and excellent customer service. And with a number of guys using their stuff, on line help usually is easy to find. For tuning software www.Tunercat.com is another vendor that has been good. Chips, often you can get a good deal on used ones on ebay.
There are dynos, and there are dynos.
The current fade are the chassis ones.
But, like all fades, they have some oddities.
Most all are using inertia wheels, and do the load measuring for 4-5 secs and extrapolate the HP from that sample time. Trouble is the it can be terribly misleading. Stay tuned, I going to be doing a post about testing. But, in short con't be surprised by inflated numbers.
Start slow, take notes, and ask guestions. It all gets clear after a while.
Ya, carbs, like doing the jetting on an IR manifold with webers is easy.
Old May 31, 2003 | 06:55 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
There is no way you will get 400 HP just by bolting on a HSR or any other aftermarket intake without other mods.
Just wanted to clear that up.
Old May 31, 2003 | 07:51 AM
86irocss's Avatar
Re: Re: Everybody is speaking greek to me!!!
Of course, I wasn't only meaning just that add on, there was going to be added: TFS G1 heads, Comp Cam 218/228 @ .050-inch lift, 24lb SVO injectors, modified MAF, 52mm Throttle Body, Headders and a 3" Cat-Back w/ a flow-thru Cat.
That will get me the 416 HP out of the 350.
Old May 31, 2003 | 08:03 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Re: Re: Everybody is speaking greek to me!!!
24lb SVO injectors,
And there is no law against using larger injectors.
Old May 31, 2003 | 08:29 AM
86irocss's Avatar
Re: Re: Re: Re: Everybody is speaking greek to me!!!
And what, may I ask, is your suggestion?
Old May 31, 2003 | 08:43 AM
Morley's Avatar
Re: Re: Re: Re: Re: Everybody is speaking greek to me!!!
24# SVO's should do nicely for the power you are looking for.
Old May 31, 2003 | 09:35 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
First read my posting on dynos.
Then read the info at RC Engineering about injectors. There just isn't the bandwidth to quote it evertime someone asks the same guestion. So don't take this as a just read the archives answer.
Then with that under your belt, understand that the gm ecm doesn't do things the same way as the aftermarkets.
The BMFC number (s) are only part of the equation.
You have to ask yourself is this for a closed loop or open loop application, and with or without cats.
So my suggestion is, after you draw you own conclusion, ask me if I agree.
Old May 31, 2003 | 11:05 AM
Morley's Avatar
Re: Re: Re: Re: Re: Re: Everybody is speaking greek to me!!!
And this is probably what he means by "Greek", no concrete answer just cryptic replies.
Old May 31, 2003 | 04:23 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
This means nothing to a beginning tuner, just makes getting into tuning ever more confusing.
86irocss, 24 # SVO’s will be fine for your setup. They are rated at the lower ford fuel pressure and when you run them at stock GM fuel pressure, they flow 25.6 lb/hour if I remember correctly.
Old May 31, 2003 | 04:40 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
No it won't.
Old May 31, 2003 | 08:26 PM
86irocss's Avatar
Originally posted by NastyL98_T/A
No it won't.
I beg to differ. With my simulator, and GM High-Tech Permormance shows it will. I actually show 330 RWHP while GMHTP shows 333 RWHP. What are your thoughts on how much you think it could pull?
Old May 31, 2003 | 11:07 PM
JohnL's Avatar
Re: Re: Re: Re: Re: Re: Re: Everybody is speaking greek to me!!!
Maybe . Or maybe the beginner tuner might see that, not only doesn't he understand the acronyms, but he really doesn't know how to ask a question yet. And he'll get a lot of suggestions from people saying things like: "tiny little injectors work in my car" without an understanding of why they may not work in someone else's.
With the (perhaps) necessarily cryptic reply, was also the offer: "So my suggestion is, after you draw you own conclusion, ask me if I agree." This is a whole lot better response than, "these will work in your car." That isn't DIY knowledge (drawing your own conclusion), that is doing what someone else told you without understanding why.
John
Old May 31, 2003 | 11:25 PM
Engine: LB9/383
You show 330? He was looking for 416. Don't get me started on GMHTP.
Old May 31, 2003 | 11:28 PM
Engine: LB9/383
Forgot to add this. I think you're simulator is close. He ought to make 330-350 (a little on the conservative side, I think it may make a bit more). The cam he mentions is sweet and I've seen some cars run their ball$ off with that cam. I'm not a big fan of dyno numbers though. You can have a dyno queen that makes 600 at the wheels and the thing could only run 13.0's. It's a tuning aid. The real test of power is the track
(sorry if I came off as a d!ck earlier. Was having a bad day )
Old Jun 1, 2003 | 04:51 AM
86irocss's Avatar
I Wasn't taking it the the wrong way, either. Don't forget that you lose HP during the transfer to the rear wheels. Now I know what they print and what really happens is two diffrent things, But GMHTP report also Track tests of best times of 12.391@110.13. That's with 14deg. inital timing and 42lbs of fule pressure.
Old Jun 1, 2003 | 05:07 AM
86irocss's Avatar
John
I understand what all are trying to say, and respect everyone's input. I have somehow gotten off the real subject, for which I have found by searching, was the speaking of "Greek". There are still some things I don't understand at this time but will come back with some(I'm sure alot) of questions.
But I would like to speak to Nasty L98 T/A more about the HSR set up. Or anybody for their input as well, on the Holly Stealth Ram.
e-mail me @ irocss89@yahoo.com
A Big THANK-YOU to all.
Matthew
Old Jun 1, 2003 | 08:39 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Hmm, seems like in his later reply he does get it.
There is nothing cyptic in my reply I told him what to do, and then check back after doing that. In the process I discribe he gets to learn more about things, and maybe discover some items that allows him to ask more and better guestions.
I didn't notice any Greek in it at all. While I did use the term BMFC, that's hardly greek to any one, and if it was a simple guestion on his part would have gotten a reply. And given he was already given a list of EFI related items I would imagine that it was listed there also.
So I don't see any merit to your critisism of what I said.
Old Jun 1, 2003 | 08:46 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
How does suggesting to someone to get more information and developing and understanding of the issues seem confusing?.
I did offer to double check his findings.
Is it really a service to just answer with xx PPH injectors?. How does that help him understand EFI?. He just stated he's a new guy, wouldn't offering sources of where to look for data seem enlightning?. heck he might even generate a greater interest and ask more guestions, and then learn even more.
Old Jun 1, 2003 | 10:30 AM
Morley's Avatar
Re: Re: Re: Re: Re: Re: Re: Re: Everybody is speaking greek to me!!!
[B.
I didn't notice any Greek in it at all. While I did use the term BMFC, that's hardly greek to any one, [/B]
If those "beginning" terms are greek to him then I would conclude that BMFC would be greek too. And no, not everyone knows what that means, especially when just starting out.
Old Jun 1, 2003 | 01:52 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Re: Re: Re: Re: Re: Re: Re: Re: Everybody is speaking greek to me!!!
Oddly enough he's posted since I mentioned that, and for him it wasn't an issue.
Old Jun 1, 2003 | 04:39 PM
86irocss's Avatar
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Everybody is speaking greek to me!!!
You're right, I have since found out (By way of suggestion by searching( a thanks to traxion's 'reprograming PROMs & grumpy)) what those terms(WOT,AFR, ect....) mean. There are still some things that are 'Greek' to my but if I don't find out what it is I'm looking for then I'll know what to ask for. But I do thank every-one for there help.
Old Jun 2, 2003 | 06:54 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Everybody is speaking greek to me!!!
BTW, your email is bouncing.
Old Jun 2, 2003 | 01:56 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
ENC 1101
Take it.
Old Jun 3, 2003 | 02:59 AM
86irocss's Avatar
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Everybody is speaking greek to me!!!
Yes, I'm having problems with my e-mail account I registered with but can be reached at irocss89@yahoo.com.
Old Jun 3, 2003 | 03:01 AM
86irocss's Avatar
Originally posted by Pablo
ENC 1101
Take it.
I'm sorry you lost me on that reply Just a learning idiot am I.
Matthew
Old Jun 3, 2003 | 03:34 AM
86irocss's Avatar
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Everybody is speaking greek to me!!!
I have updated my profile with my working e-mail account.
Old Jun 5, 2003 | 09:43 AM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
that wasnt directed toward you
Linson
Oct 24, 2025 02:00 PM
scotrans am
European Region
May 30, 2018 03:48 PM
BADNBLK
Convertibles
65
Feb 10, 2016 03:36 PM
david068513
Sep 18, 2015 10:36 AM
HrdRockA4305
Dec 9, 2007 07:14 AM
