What gear ratio is the common 16151348 MEMCAL
My vehicle has 3.42 gears and I'm considering bypassing the VSS buffer and connecting the VSS directly into the ECM. I'm using the very common 16151348 MEMCAL (that's the one found on Mike Davis' site).
If this MEMCAL is not setup for 3.42 gears, is there a way in Tunercat to adjust the speed?
Car: An Ol Buick
Engine: Vsick
Re: What gear ratio is the common 16151348 MEMCAL
I'm currently working with the $8D definition. There doesn't seem to be anything there to change the gear ratio. I see a "road speed constant", but is this the value I want to play with to change the ratio?
I'd like to know what ratio that memcal is setup for. I'm still using a VSS buffer in my vehicle (because I used to have a 165 ECM) and plan to get rid of it and connect the VSS to the 727 ECM. Chances are the speedometer will be incorrect. So my TCC lockup will also be screwey.
If the memcal is not calibrated for 3.42 ratio, then how can it be adjusted?
Am I making sense?
Am I making sense?
Hotrodboba400
Dec 10, 2019 07:07 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
