Where do i start with my configuration?
Car: 92 quasar gta
Engine: Nothing
Transmission: Nothing
Axle/Gears: 4.11s
This week i plan to finally fire up my car..
ill be running with basically:
stock bottom end 350
218/218 .550/.550 crane cam
pro lightning 180cc heads
super ram
24lb injectors
adjustable afr
92 ecm w/ MAP system
I have a hypertech stage II prom but i also have all the stuff to burn proms.
ive read every article but most are for minor changes on running cars.. is there any way to get it close right off the start so i dont kill anything...
super ram
24lb injectors
adjustable afr
Car: 04 GTO
Transmission: M12 T56
Combo's not that radical, it would run decent enough off a stock chip to get you started. If you want to be safe i'd cut maybe 10-15% off the VE below 1000rpms and maybe 5% up to 2k.
Car: 92 quasar gta
Engine: Nothing
Axle/Gears: 4.11s
i think my tranny is gonna disagree with the radical thing once its running.. ill cut the curves though as suggested and see how it goes..
probably wont be seeing WOT much off the bat
btw ed.. nice conv z28! gotta love that blue
92 GTA
92 GTA
Car: 92 quasar gta
Engine: Nothing
Axle/Gears: 4.11s
yep..quasar blue.. one rare gta :lala: probably the only one like it in canada and i ripped it apart
for the better of course
92camaroJoe
Aug 13, 2015 06:07 AM
