Manual Bin Spark timing
Old Jun 16, 2003 | 03:15 PM
TheTPIGUY's Avatar
I just converted to the Holley Stealth Ram in my car with a 350 and 224/224 @ .050" cam. The problem I am seeing is that, between shifts, there is a loud pop and a loss of power. I attribute this to the fact that I am using an automatic car .bin and, when driving a manual, between shifts the rpm's and Kpa drop where as an automatic simply rolls over to the next RPM at a constant load. My question is:
What value is acceptable for timing at low kpa values between shifts?
Has anyone else had this problem and how did you remedy it?
Old Jun 16, 2003 | 03:59 PM
funstick's Avatar
are you canadian ?
Old Jun 16, 2003 | 04:55 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
This is just my experience, but in my tuning days I noticed if I didn't run enuf timing in the high vacuum areas (20-30 kPa) it would start popping like you described.
I think you might also want to adjust some of the throttle follower stuff to let the RPM "hang" between shifts.
Old Jun 16, 2003 | 07:39 PM
TheTPIGUY's Avatar
Out of curiosity, how much timing was "enough". I would think that the engine would require less timing under no load conditions. Where exactly did this timing come into play (RPM load etc...)
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
ezobens
Aug 19, 2015 10:29 PM
