about fuel maps.
Old Jul 3, 2003 | 11:12 PM
devilfish's Avatar
about fuel maps.
hello
As all of you know it can be hard to get all the diffrent Map/load "areas" scaned when you drive.
Specially the really high ones ( due to engage PE mode ), and the low ones 0-30.
So what procedure do YOU use when you tune that area?
I got pretty good BLM scans from idel to around 3000rpm, but almost only in the 45-60 Map range. Now is it "ok" to use the graphical inteface in TUNERCAT to just smooth out the points that is below and abow the scanned areas I DO have ( 45-60 ) MAP, in other words the 0-45 and 60-100 Kpa areas?
I hope you understand what im talking about.
How is the "trend" in the fuel maps?
When I look at the stock bin i se that "GM" use a pretty steep intervals from 0 - 40MAP, then it smooths out from 40-70, then it gets pretty steep again to 100 MAP. Is this unik from car to car, or is it "rule" in fuel maps?
thanks
Old Jul 3, 2003 | 11:56 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Take a trip on some roads with alot of hills.....
Alf here in southern sweden used to do this when he "tuned" his cars to get the upper areas......
You have probably seen his cars in shows/magazines......
http://www.osterlen.com/alf/Tempest-67/Race.htm
http://www.osterlen.com/alf/GTO-66/GTO-66.htm
Did you get the PROMS?
/N.
Old Jul 4, 2003 | 12:06 AM
devilfish's Avatar
yeah I know about the "hill" trick. But I can be hard hard to get all of the loads anyway
Nice GTO.
I did get the chip BUT there seems that my prom burner dont support the 29c256 ATMEL chips. I talked to the vendor and he should look it up for me..
Old Jul 4, 2003 | 11:08 PM
papaford's Avatar
how do you do it when you have no hills,,
I live in southern florida.... flat.....
Old Jul 5, 2003 | 06:04 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Grab some big friends, and do some tuning with them on board.
Or bags of sand, you do have sand down there right?. LOL
400 lbs or so, or a trailer, can give some feedback on things.
And if you go with the min timing consistant with performance you'll not be in the detonation trap anyway.
Old Jul 5, 2003 | 08:10 AM
JohnL's Avatar
You can make big hills out of little hills by driving with your brakes on- works for me
As you say though, getting the numbers at high load/rpm is difficult. More time or a dyno needed.
There is no rule for the shape of the VE vs MAP vs RPM surface. This will vary with your cam, heads, manifolds, yada yada...
John
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
mike_c
Aug 27, 2015 04:32 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
