trying to get idle for AC up
Old Jul 4, 2003 | 04:45 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
87 165 ECM using tunercat and $32B file. specific one i used was the idle speed adder for ac on. originally set for 50 rpm. i raised to 200.
and there was no change. turn AC on and idle still drops. so i'm missing something obvious.
Old Jul 4, 2003 | 05:13 PM
funstick's Avatar
iac steps for ac anticipate would be my geuss.
Old Jul 4, 2003 | 05:41 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: trying to get idle for AC up
As mere speculation, I'd venture someone has steps labeled as RPM, and they are using a x12 or x25 multiplier in there, so your rpm label maybe an error. In that case your just moving the IAC an 8 count and isn't enough to comp for the load. Try increasing the value to say 14 and see what happens.
Try looking at what your IAC steps are before and after, turning it on to make sure you got the right dohiccy <G>.
Often there is a hot start A/C on adder, which might be what you tweaked.
Old Jul 4, 2003 | 10:47 PM
mrr23's Avatar
Engine: 360 HSR
it's in the tunercat constant table. specifically says RPM. pic here. but i thought that IAC was what changes. tomorrow i'll see what my IAC is off and on. i may be at my limit and will need to turn the TB idle screw up and readjust the TPS. then go from there.
Old Jul 4, 2003 | 11:53 PM
funstick's Avatar
actually that adds 50 rpm as the AC compressor comes on and pahse back to a normal idle speed.
Old Jul 5, 2003 | 05:58 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
There's alot of things that read one way and to some extent make sense. But all is not as it seems.
If the IAC and RPM counts were exact then You'd have to have idle IAC counts in the 60s for things to line up.
Old Jul 5, 2003 | 11:05 AM
mrr23's Avatar
Engine: 360 HSR
my point is that if my IAC counts are about maxed out, say 140, then i'd have to adjust my TB up to get the counts down.
Old Jul 5, 2003 | 11:17 AM
mrr23's Avatar
Engine: 360 HSR
ok iac count is in the 60s. turn on the ac it goes to 145. keeps same idle 600ish. i may just need to turn the idle screw up to 700. or should i change my target idle.
Old Jul 5, 2003 | 11:59 AM
mrr23's Avatar
Engine: 360 HSR
at 180* temp the IAC counts are 0. turn on AC and it goes to 145. idle 650. i'm going to bring the closed loop target IAC rpm vs coolant to 750. it's at 600 now.
Old Jul 5, 2003 | 03:29 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Yes, your min air setting is off.
Typically, folks run 0-15 IAC at idle.
Then you might double check the TPS voltage at idle, and WOT to see where you are.
Old Jul 5, 2003 | 07:37 PM
mrr23's Avatar
Engine: 360 HSR
the idle screw is set too low. so i turned it up. now it's fine. the TPS is .58 at idle and 4.60 at WOT.
Old Jul 5, 2003 | 08:05 PM
funstick's Avatar
a few things come to mind. dirty.clogged.blocked IAC passage. BAD IAC. incorect IAC with incorect pintle. however at 145steps the thing should be at like 2200rpm no load in p-n.
id check the IAC and the IAC passages. i had similar issue when i first converted my honda Cold air bypass into a IAC housing. it took me a while to figure out why it would idle with 160 steps. until i found the pintle head was the wrong shape and the housing had a clog in it. oncei did that i got it to idle with a nice steady 5-10 steps in every weather and with the a/c on it holds it at 45 steps.
Old Jul 5, 2003 | 08:10 PM
mrr23's Avatar
Engine: 360 HSR
brand new IAC housing (about 6 months old). new IAC (same age). but i'll keep playing with it. with the idle turned up i'm back into a lean condition at idle. need to play with the MAF tabe 1 again.
Old Jul 6, 2003 | 12:39 AM
funstick's Avatar
check for incorrect gaskets blocking things off
Old Jul 6, 2003 | 01:29 AM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
All's I have to say is "Man, you should see what I did with my IAC..."
On a 383, it will control idle RPM from 700 to 1800rpm. Holds tight around 800rpm at ca. 10 counts, and that's what it seems to like. Tried the adder for A/C, that helps too. Gotta have a good clean bore to pass the air. Mine's a little different and required some port work (yes, on the IAC passage).
What is nice is to have the 'Neutral' setting a little higher and that way when it drops into gear it's right where you want, no stumble. That's on an auto anyhow.
Keep in mind that the little IAC valve takes a second to react and what not, so it has to track what you ask of it. Dynamics in that.
junior419
Apr 7, 2025 11:35 AM
Grant2k
Apr 4, 2016 08:21 AM
86IROC112
Nov 27, 2015 09:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
