DRP occured?
Old Jul 20, 2003 | 11:47 PM
TORC's Avatar
DRP occured?
I'm dialing in a chip for a new engine, using the 7747 and I'm getting a the flag "DRP occured" as well as intermittent "Rich" flag. What the hell does the DRP occured mean?
Thanks....
Old Jul 21, 2003 | 12:14 AM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
You spilled water on the chip (DRiP)? LOL, had to.
Old Jul 21, 2003 | 12:30 AM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
The best I could gather it stands for "Distributor Reference Pulse". The drp is what instructs the injectors to pulse in sync. That may give you a heads up on what the problem may be. Do a search and you should find many topics on the subject. I read that sometimes you may get this code and it is just letting you know its working properly so it may just be showing everything is fine.
Old Jul 21, 2003 | 03:49 AM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
The intermittent Rich flag is okay also. It should toggle back and forth. Your computer is continuously making adjustments based on the O2 sensor readings. So, it will toggle back like that. If it stays on or stays off then there is a problem. What are you BLM's?
Old Jul 21, 2003 | 10:00 AM
TORC's Avatar
Ok, so what I'm hearing is that the DRP thing most likely isn't a concern since it's basically running smooth as glass. Also sounds like the flashing rich flag is a completely normal thing as well. I haven't had the chance to drive the vehicle yet, so I've only gotten BLM's in two cells. Breaking in the camshaft gave me a BLM of about 120 @2000rpm/~38kPa and at idle a BLM of about 140 @ 800rpm/~31kPa. I can see already though that I'm going to need to be making some adjustments to the fuel map
Old Jun 3, 2006 | 04:30 PM
kurtrangen's Avatar
you guys rock. You answered my question. my closed loop flag comes on and off is it susposed to.
antman89iroc
36
Jan 31, 2016 08:42 AM
mfp189
Sep 27, 2015 09:25 AM
WhteRbt
Sep 21, 2015 09:48 AM
Americanmouse
Sep 7, 2015 12:10 PM
Eric2ndGen
Aug 31, 2015 12:33 AM
