I can't get my idle BLM's lower than 160 no matter what I do!!
Old May 31, 2006 | 10:28 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
I have a 87 GTA running the MAF 6E system. Every single year I get it out of storage something always seems to change on it, and I will have to readjust the fuel to get it to run right. This year it idles very lean, the blms go right to 160, I have adjusted the injector constants, maf tables, pulse width verse batt voltage and nothing changes it, I went both ways lean and rich, little changes, big changes, nothing helps. I am using the tunerpro rt with the autoprom. Any ideas???
Old Jun 1, 2006 | 07:37 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Low fuel pressure?
RBob.
Old Jun 1, 2006 | 07:47 AM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
Does your O2 sensor work at all?
Old Jun 1, 2006 | 08:14 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Either of the above or either on the verge of complete failure will do it.
Vacuum leaks.
Dead cylinder?
later
Jeremy
Old Jun 1, 2006 | 05:49 PM
AaronIROCZ's Avatar
Well I just replaced the o2 sensor last year ( but that doesn't mean that its not already bad ) and the fuel pressure is at 42 psi at idle. I will double check the o2 sensor and get back to you.
Old Jun 3, 2006 | 04:34 PM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
Bad or dead fuel injector?
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
ezobens
Aug 19, 2015 10:29 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
