BLM’s peg to 160, in closed loop on lightly moded 305, HELP!
Old Jul 29, 2003 | 07:21 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
My brother’s car has been problematic for about a year now. It has been sitting for quite some time because we can not figure out how to fix it. It is a 92 Z28 with a 305 TPI lightly moded; ported heads, shorty headers, G92 dual cats, and some other little things.
When you start it up it runs fine, idles smooth, drives fine. But once it heats up and goes into closed loop it runs horrible. The BLM’s peg to 160 the exhaust starts popping, the idle becomes very rough.
Here is what we have tried to fix it:
- Replaced injectors
- Replaced O2
- Started with a fresh copy of a factory bin
- Checked timing, set to 6 degrees advance
- Checked wires, plugs, coil, cap and rotor
- Checked fuel pressure, holds 42 PSI
Anyone have any ideas what could be causing this?
Old Jul 30, 2003 | 12:39 PM
Denis.V's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
- Vacuum leak?
- Air leak in intake runners?. Causes could be: cracked intake manifold, cracked int. manif. gasket, bad intake man./head ports matching, then the mixture will be AIR/FUEL + AIR = lean.
Old Jul 30, 2003 | 12:55 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: BLM’s peg to 160, in closed loop on lightly moded 305, HELP!
- Replaced O2
Either severe exhaust leak, O2 sensor lead melted/shorted on manifold, bad ground(s), or the divertor valve/air pump system is bad.
RBob.
Old Aug 4, 2003 | 09:50 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Today I unhooked the smog line to the driver side header and put a plug on it. Now the BLM’s are at 113 on a stock chip at idle!! I replaced the smog check valve on the header with one I know works off my Camaro and the BLM’s went to 158, that’s a 45 BLM difference between smog hooked up and unhooked. So it’s has to be something wrong with smog, but what??
This also raises another important question, how much does a fully functional smog system affect O2 readings (I know not as much as my brother’s car)? Has anyone noticed a few BLM’s of difference with it on compared to off?
Old Aug 5, 2003 | 06:37 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The air pump does not actively induce air into the exhaust pre-O2 sensor while in closed loop. So there is no effect on the BLM's.
It actually sounds like there is still somehting wrong with the system.
On a '92 TPI the air will only go to the exhaust ports during cold engine operation. With a warm engine the air then goes to the cat-con.
The air will be diverted (dumped) during: rich operation (RE), ECM trouble code set, deceleration, during high RPM operation.
RBob.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Jae992
Aug 27, 2015 09:07 AM
ezobens
Aug 19, 2015 10:29 PM
Omega
Aug 10, 2015 12:46 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
