Lockers0.zip request
Car: 91 Red Sled
ftp.diy-efi.org is down and I'm looking for the Lockers0.zip file that was posted by RBob.
Bob, slight problem if you could e-mail me at formulabuckeyes@yahoo.com
Nothing serious, I got my ecm modified and everything works out great, just curious on getting some other software and after file outputs are "edit capture.ful" there are no titles to the columns of data, even the capture.bpw etc.
Car: check
Engine: check
Transmission: check
Re: Lockers0.zip request
Originally posted by JPrevost
. . .after file outputs are "edit capture.ful" there are no titles to the columns of data, even the capture.bpw etc.
If you just gather key on, engine off data, there column titles do not get output (because the EngRun timer does not increment).
RBob.
Car: 91 Red Sled
Re: Re: Lockers0.zip request
Originally posted by RBob
The column titles are output whenever the EngRun time counter increments. This is each 1 second of run time.
RBob.
RBob.
.What about that software you had hooked up to the test bench. That seemed to have everything on it I would need to diagnose problems such as tcc having fits etc. Maybe I'll write some windows software that charts out the data realtime so you can see obvious AE issues.
tonys91rs
Oct 10, 2015 03:31 PM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
