1227730 and pins BB11 and BC1
Old Aug 14, 2003 | 08:37 AM
Swapmaster's Avatar
I swapped from a 165 to a 730 ECM and need a 2K signal for the speedo. I tried using BC1 with no luck and then BB11 just to try to get the speedo to move with no luck.
I show a speed reading in Datamaster but no voltage a on either pins while the car is moving. I have tried 3 different ECM's with no luck. I am using the $8D code in Tunercat and don't see anything to do with speed sensor outputs.
What am I missing?
What would prevent an output signal on BB11 or BC1?
Old Aug 14, 2003 | 10:07 AM
Swapmaster's Avatar
Never mind, I got it figured out. Jsut hook the speedo directly to the yellow wire going to BB10. It is an A/C signal at 4000ppm but a device looking for a D/C current only sees half of the sign wave and only reads it as half. So I got my 2000ppm signal and the speedo works fine now.
wigmobile
Feb 26, 2025 02:56 PM
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
gta892000
Sep 16, 2015 12:37 AM
