ECM error
Old Aug 15, 2003 | 05:59 PM
JJ63's Avatar
Car: 92 Trans Am
Engine: 350 tpi
Transmission: 5 Speed
ECM error
I've been trying to get my car working after an engine swap. With the key on and engine off, the fans come on and I'm unable to connect with Moates software. With the ALDL jumped I'm unable to even get the check engine light to flash codes. The light just stays on. I'm using a moates adapter and I've tried 2 different memcal all with the same problems. I bought a new ecm from autozone, still no help. The speedometer doesn't work so does that mean the vss is bad or is the problem with the ecm preventing it from working? Would a bad vss stop the ecm from sending codes? What would prevent the ecm from working corrrectly?
I have a 355tpi, 730 ecm, sd, 5-speed. I was thinking that the pocket programmer was buring incorrectly, I'm using their old 1.34 software with windows xp. But I tried using an old prom from Performance resource and I still get no readings.
Old Aug 15, 2003 | 09:52 PM
JohnL's Avatar
You say you're trying to get your car working, but the speedo doesn't work (which won't stop the engine from running). Will the engine run at all?
A bad VSS is most likely to give you a problem with stalling as you coast to a stop- it won't stop the engine from running. It could light the SES light though (not on ECM I'm familiar with), and it will store a code.
Did your car originally come with a 730?
John
Old Aug 16, 2003 | 06:04 AM
JJ63's Avatar
Car: 92 Trans Am
Engine: 350 tpi
The engine starts and runs, though very rough. I'm sure it's in limp home mode and not running off my burned chip. I have to goosing it to keep it lit.
The car is originally a 92 5.0tpi with the 730.
Bad grounds? I read where the ecm is supposed to be ground to intake manifold. I don't see any wires that meets that despription on my intake.
Old Aug 17, 2003 | 04:54 PM
LetsRock's Avatar
Car: 1989 Trans Am GTA
Engine: LB9 TPI with L98 cam (Manual car)
Transmission: T5 5Speed/ 9bolt Borg-Warner 3.45 gears with posi
Its a prom issue, the ecm doesnt recognize the program you burned or something. I had this same issue until I found a prom correct for my car (almost) I still havent fixed the speedo issue.
Look into your programming on the prom.
Old Aug 18, 2003 | 06:54 PM
JJ63's Avatar
Car: 92 Trans Am
Engine: 350 tpi
The prom was the problem. I was using an old Performance Resource prom as a tester and as the starting base. I guess after two years of it sitting on my shelf, it partially erased. I reburnt a couple proms using a different staring bin and no problems. Thanks for your help.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
Jlanz55
Sep 29, 2015 08:55 AM
3rdgenparts
Sep 28, 2015 10:47 PM
mfp189
Sep 27, 2015 09:25 AM
