Microtech MAF Calibration
Old Aug 26, 2003 | 08:12 PM
Bluevette85's Avatar
Car: 85 Corvette
Engine: 355 Superram
Transmission: 700R4 Transgo Shift Kit
I bought a Microtech MAF from Advance Auto that fits 86-89 TPI cars (165 ecm). It is the film type and I believe they make them for Wells also.
The output voltage for all airflows is 0.3 volts higher than the Bosch MAF. I made my own air flow bench and compared the two MAF's. This results in a very rich condition with the stock MAF tables.
Is there a way to alter what incoming voltage the ecm sees? Could I put a resistor on the MAF signal line to drop the voltage by 0.3? I have reprogrammed my ARAP bin by changing the MAF table scalar values then adjusting the tables but I wanted to know if there was another way to make it work.
I returned the first Microtech but the second gives the same readings so they are programmed that way from the factory.
Mark_ZZ3
May 24, 2018 01:02 PM
BumpaD82
Feb 26, 2016 02:57 PM
racereese
Oct 3, 2015 03:46 PM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
