165 ECM Dump from Moates Software
Old Sep 4, 2003 | 03:12 PM
johnh's Avatar
Car: 2004 GTP CompG
Engine: L32 SC
I can't seem to get the ecm dump option to work. I have my own built 2 transistor cable. Everything connects fine, except I can't get it to dump the eprom. I want to get a back up before I start doing the custom prom stuff. (Plan B is to unsolder the prom out of the memcal..but I'm afraid I might damage the chip in the process, plus it'd be nice to keep the stock one as a paperweight)
I have an 89 Firebird L98...stock ECM. I use the program default it says "can't connect to car"....all the other screens work fine. (BTW the speed timing page rocks...6.2 0-60 best so far. )
Should I change the default address $C000?
Another question should I leave the 10K Resistor connection hooked up between A&B?
Old Sep 4, 2003 | 09:19 PM
JohnL's Avatar
Are you trying to suck the .BIN out through an ALDL cable? Didn't know you could do that.
I think you need one of these:
John
Old Sep 5, 2003 | 12:07 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
I have done this with the two transistor cable and moates software, it was the only way to extract the bin from my jet stage 2 chip, but its been so long ago since I did this I can't remember what I did. Try it with the car off and the key in the run position, I think thats how I downloaded it a few times.
Old Sep 5, 2003 | 07:51 AM
KAOSRacing's Avatar
I haven't been able to pull the bin from my 165 using Craig's software either. I have tried to do it with the engine off but the key in run...no luck.
Old Sep 5, 2003 | 09:52 AM
Tony89GTA's Avatar
Car: 89 GTA
I was using a older version of his software at the time, maybe that makes a difference.
Old Apr 9, 2004 | 10:49 PM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
Did you all ever resolve this issue? I am having the same problem, but with 730 ecm. Thanks!
Old Apr 10, 2004 | 09:16 AM
poncho@home's Avatar
Car: 2004 BMW 330Cic
Engine: 3.0
Transmission: 6 speed
it works fine for me. 165 with v8.52 of moates using 2 transistor cable
Old Apr 10, 2004 | 09:58 AM
SMasterson's Avatar
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
I may be remembering this wrong since it's been a long time but it seems with my 165 ecm I had to use decimal numbers when telling the program the size of the bin I was downloading.
Maybe?
Old Apr 11, 2004 | 12:50 PM
JMatlock88's Avatar
Car: 1991 Formula
I tried base 10 numbers.
Old Apr 12, 2004 | 05:41 AM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
It ought to work. You need to 'connect' first and then go to the dump page. Like you say, gotta use decimal. Might be an issue with the newer software version too, haven't messed with it in a while. The older version (850 or 852) should work. Of course you've gotta be in '10k' mode to connect.
Old Apr 12, 2004 | 04:52 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
I did it using ver 8.50 I believe...over a year ago...and it worked fine. Through the ALDL cable, of course
The engine wasn't running...but the key was in the "on" position...I was testing the TPS and CTS temp values and then I did the dump...3 seperate times and it worked each time.
BTW...165 ECM with a 10K resistor in...and it obviously allowed me to connect. I would check your cable, or find a different 165 ECM to plug in and try to connect.
HTH,
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
