What the Heck is this Thingie?
Old Dec 10, 2003 | 10:12 AM
  #151
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Originally posted by 1bad91Z
I'm buying the first one to develop or incorporate a wide band controller into it ! Looks like Craig's has the hardware to one day handle it!
You can do it with the stock computer now so how is that any better?
Tim
Old Dec 11, 2003 | 08:37 AM
  #152
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
Tim
I think that he is talking about only having one computer to scan ALDL and monitor the WB02 at the same time.
All you would need is one imput to read the voltage of the WB02 and a display (program based) to know what the voltage means and print it to the screen. The main question for this would be, "do all of the WB02 uses the same voltage?"
Old Dec 11, 2003 | 10:34 AM
  #153
TRAXION's Avatar
You've lost me because that's how I do it now ... with only one computer used to scan the ALDL. I use Datamaster on my laptop plugged into the ALDL. There is no other computer.
Tim
Old Dec 11, 2003 | 01:32 PM
  #154
bigals87z28's Avatar
Car: Check The Sig
I have another newbie question, how easy is this going to be to install into the ECM? I mean is there a chance that I can fawk up the ECM (other then means of static electricity or other stupid things) or screw up the acutaly device? Does it just plug in come where in the ECM?
Old Dec 11, 2003 | 02:50 PM
  #155
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
WBO2 integration into the existing ECM via the GM ALDL datastream is all the rage. That's what I use on the 1227165. Works like a charm, with my own personal hack. I love it too.
From the perspective of someone wanting to log a WBO2 or other 0-5v signal through their serial port while they are performing emulation and regular ALDL datalogging through the very same port, independent of a BIN hack which allows the WB to come in on a typically unused pin on the ECM harness like Tim and I do, then the unit will provide an advantage.
For instance, say you're logging data from a 95 LT1. You can use the AutoProm with TunerPro software to log the normal ALDL datastream to disk or to graphical plot. Coincident with that logging, you can log the 0-5v signal coming from the WBO2 signal. So, you end up with a datafile that has Time, RPM, TPS, WBO2V, MPH, etc, etc.
Of course, datastream definition as well as voltage-to-whatever functions for the A/D can all be defined within TunerPro. So you look at that AFR-vs-Volts curve, you plug in a table in TunerPro, and it will do the calcs for you. Or, if you have something else hooked up (like a Ford MAF and/or TPS and/or etc), it can do the conversions separately, so you have a separate transfer function for each input.
I think the key point is that there are always other ways to accomplish similar tasks. While we may be doing something in one way today and be satisfied in that regard, that does not mean that it's the best way or that it's the only way.
Does this make any sense?
Old Dec 11, 2003 | 03:00 PM
  #156
TRAXION's Avatar
Craig,
That makes perfect sense. Thanks for pointing that out! How are you sync'ing each ALDL item per time interval with the extra items on the other inputs to ensure that everything is truly on the same timeframe? Any answer you give I probably won't understand I guess I'm just looking for you to say that you have already thought about this and have taken care of it. Each 'get' for info on the spare ports has to be totally in sync with each item in the ALDL stream.
Very cool on what Mark is doing with regard to allowing users to customize data conversion with regard to these spare inputs. I think this absolutely rocks. Very awesome.
Tim
Old Dec 11, 2003 | 03:08 PM
  #157
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
The additional A/D info will be accessed via commands, much like the ALDL stream is accessed. The only thing TunerPro needs to do to access it is send an additional command. Thats how the data will be acquired. They won't be absoultely simultaneous, but of course you realize that there is a delay with the ALDL information that the ECM provides caused by both the ECM's processing of the data and the time it takes to be passed via 8192 baud. So any delay or timing issues would be minimal.
It should be noted that Craig is speaking more about a hypothetical example and about possibilities rather than about what "is".
There are plans for what he speaks of and more more. The framework is there. This stuff will evolve (as he and I agree) "to no end".
Old Dec 12, 2003 | 11:36 PM
  #158
72LT1VETTE's Avatar
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
The new board offers very much. How much will the slow processor speed of the 165 & 730 ECM's impare
it's abilities?
Old Dec 13, 2003 | 02:36 AM
  #159
Mangus's Avatar
Transmission: T5WC
it's abilities?
The AutoProm functions independantly from the ECM's processor(s), and therefore their speed makes no difference.
ALDL sample rate is limited more by the baud of the data transmission than of inherent speed of the processor.
Old Dec 15, 2003 | 12:21 AM
  #160
turqgolf's Avatar
Car: 90 vette, 91 firebird
Engine: l98, lt1
Transmission: zf 6 sp
1227727 auto prom
Wow this is great!
Will this unit work with 1227727 ECMs these are the weather pack versions of the 730 Ecm.
I appoligize if I have missed an answer to this earlier
Old Dec 15, 2003 | 05:53 AM
  #161
Car: 87 T/A
Status Update:
Right now everything's on hold. Doesn't look like this project is going to work out after all.
Just kidding! As of today, all the primary functions have been shaken down and found to be pretty robust. Emulation, ALDL datalogging, and chip programming are all working solidly. Field updates of the firmware are also working great. The first round of beta testing units should go out toward the middle to end of this week. If there are no show-stoppers, then orders will be taken right before Christmas.
Old Dec 15, 2003 | 06:07 AM
  #162
Car: Check The Sig
sorry if this has been asked, but a few questions for a someone new into this field.
1- How much ball park?
2- How easy is this going to be for a new guy like me to understand and use?
3- How exactly is this installed into the ECM?
4- Is there new software that will go with this hardware?
Old Dec 15, 2003 | 12:41 PM
  #163
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
Originally posted by Craig Moates
Status Update:
Just kidding...
AHHHH Don't do that to me! Excellent work Craig!!
Old Dec 15, 2003 | 07:26 PM
  #164
72LT1VETTE's Avatar
Engine: 350 HO
Axle/Gears: 336
Hey Craig, Think there is any way to incorporate some type of position trigger, wiring mods, and outputs for sequential firing of the injectors? Maybe another project during evolution? HaHa GREAT WORK!
Old Dec 16, 2003 | 08:22 AM
  #165
Craig,
Maybe on your homepage you can set up a feedback area where we can submit some ideas to you. Sometimes ideas are all that are missing.
Just a thought.
Old Dec 16, 2003 | 02:36 PM
  #166
Mangus's Avatar
Transmission: T5WC
Yikes Craig. I think you were just Marooned. He seems to suggest that you're lacking ideas.
Its OK, though. I believe in you Craig. I believe in you!
(Maroon - why not post your ideas here. Or, better still, in Craig's message boards?)
Old Dec 16, 2003 | 04:02 PM
  #167
Car: 87 T/A
Mark, your sarcasm is so very subtle!
Reminds me of that scene in "A Few Good Men"...
"You can't HANDLE the truth!"
But yeah, as beta testing cranks off this week, I'll go ahead and prepare a place at www.moates.net in the meager forum over there to harvest ideas, issues, and solutions. This is an eternal project as you might have gathered.
Old Dec 16, 2003 | 08:52 PM
  #168
Car: 87 T/A
Tested and working on a C3 ECM tonight. 1228747 TBI truck, worked like a charm with 24-to-28 pin adapter. Sweet...
Old Dec 16, 2003 | 11:43 PM
  #169
funstick's Avatar
the day craig runs out of IDEAS ill lay a golden egg. hes worse then i am and im bad !!!
Old Dec 17, 2003 | 07:20 AM
  #170
jeepguy553's Avatar
Car: 1980 Jeep CJ7
Engine: AMC 360 with GM TBI
Transmission: TF727 set for kill...let's get it on!!!
That's music to my ears...
Old Dec 17, 2003 | 01:02 PM
  #171
Ok, before I get flamed by people who don't read all of the posts, and we know that 70% of the tgo members don't....
I meant that as, if we all share ideas and craig had a forum or feedback area then the posts here wouldn't ever be doubled or overlooked. I know craig has a lot of ideas, and that is where this came from, but if tuners, like myself, do things different or have some ideas for programming/hardware/etc to help out, then maybe Craig can add it with the firmware for the upgrades....all I meant.
Anyway, just waiting for the release date to the non-beta public.
Old Dec 17, 2003 | 01:43 PM
  #172
Car: 87 T/A
I've set up a forum for the AutoProm at:
http://www.moates.net/phpforum/
I encourage anyone who has questions, suggestions, or commentary regarding this device or related developments to post and keep an eye out there.
Additionally, I will try and keep a 'digest' of FAQs, features, weaknesses, operating instructions, and related information closely linked.
If items in this section are easily 'digested' or redundant, I'll incorporate them into a more singular document. This way, the spirit of 'one-stop' is preserved.
Keep in mind that if you have a question or idea, there are others out there that might be thinking the same thing. No quetion is a stupid one, except that which isn't presented.
Old Dec 17, 2003 | 01:45 PM
  #173
Mangus's Avatar
Transmission: T5WC
actually, questions like:
"how much do you think it would cost to carpet Florida?"
are kinda stupid.
Old Dec 17, 2003 | 03:00 PM
  #174
Car: Check The Sig
are kinda stupid.
WELL SOME PEOPLE WANTED TO KNOW!.....*goes to cry in corner*
Old Dec 17, 2003 | 06:33 PM
  #175
funstick's Avatar
are kinda stupid.
wel florida is 65,578 sq miles
that works out to 203,134,412,800 Sq yards
Now if burbur is say what $7.80 a yard on sale at home depot
thats $1,584,448,419,840
Thats just for carpet. Imagine how much padding and instalation will run if install is $1.50 per yard
pad is $3.50 per yard
ok so let see how much this really costs
for padding and installtion at $5.00 per yard
$1,015,672,064,000
for a grand total of
$2,600,120,483,840
You could carpet and Pad and install burbu in florida. And burbu is so damned nice carpet.
have a good day.
Old Dec 17, 2003 | 06:47 PM
  #176
Mangus's Avatar
Transmission: T5WC
Originally posted by funstick
Hey how many square miles in florida ?
to carpet florida
Sqaure miles/3 x price a yard x price a yard for install x price for padding per yard.
put all that in and youll have the cost to carpet florida.
you meant sq. miles/9, right?
ok, ok. it was a stupid question to begin with, remember?
Old Dec 17, 2003 | 07:02 PM
  #177
funstick's Avatar
hey criag said
[qoute]there are no stupid questions[/qoute]
so hey i treated it that way
Old Dec 17, 2003 | 07:37 PM
  #178
Car: Check The Sig
the man knows his carpet... is that a good thing?
Old Dec 26, 2003 | 11:49 PM
  #179
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
to my understanding it works on a tbi car right? and would the baud rate be 160 still or 8192?
Old Dec 27, 2003 | 08:44 AM
  #180
Car: 87 T/A
Yes, it works on a TBI car. I've tested it on a TBI truck (91), and it seemed to work fine.
It will still be 160 baud, however, the communication will be pretty trick (once I get through with that section). It will ultimately be capable of simultaneous logging and emulation with 160 baud as well, but for the moment that feature only works with the 8192.
However, the device will still work for 160 baud communication. You'll just have to flip a switch on the device and use a program like WinALDL.
Old Dec 28, 2003 | 06:41 PM
  #181
jeepguy553's Avatar
Car: 1980 Jeep CJ7
Will this be available via firmware update?
Old Dec 28, 2003 | 07:23 PM
  #182
Mangus's Avatar
Transmission: T5WC
yes. the feature list will continue to grow thanks to user-updateable firmware.
Old Dec 28, 2003 | 07:40 PM
  #183
jeepguy553's Avatar
Car: 1980 Jeep CJ7
I believe you guys may have me sold here. Put my name on the list when you get ready to start releasing them.
BTW...Mangus, that guy that was giving you all that crap earlier deserves to reap the benefits of what he is sowing so to speak. (I say that lightly because I don't want to get "Napstered" for libel...IN MY OPINION he seems like the kind of guy that would happily Napster someone for anything just to make a buck. I wonder what the name of his trailer park is.) Anyway, you guys kick ***!!!
For any ambulance-chasing shyster lawyers that are reading this...I am entitled to my opinion by the FIRST AMENDMENT to the CONSTITUTION OF THE UNITED STATES OF AMERICA and if you don't like that, you can kiss my hairy white ***!!! I fought TWO wars to defend that right and I will defend it to the end.
Old Dec 28, 2003 | 09:16 PM
  #184
11sORbust's Avatar
BTW...Mangus, that guy that was giving you all that crap earlier deserves to reap the benefits of what he is sowing so to speak. (I say that lightly because I don't want to get "Napstered" for libel...he seems like the kind of guy that would happily Napster someone for anything just to make a buck. I wonder what the name of his trailer park is.) Anyway, you guys kick ***!!!
Mangus, that guy is retarded. His software is just hashed over ecu's. Nothing that great.
You are the man!!! I can't wait to try the autoprom.!!
Old Dec 28, 2003 | 09:44 PM
  #185
PonyKiller87's Avatar
Car: 87 Iroc Z28
Engine: 355 TPI
Please Put my name on that list, I deffinatly want one of these when they are released for sale.
Old Jan 4, 2004 | 08:09 PM
  #186
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
i want one of these also, im gonna swap out my tb ecm for a tpi ecm thanks to the help of some fellow board members
Old Jan 4, 2004 | 09:48 PM
  #187
Car: 87 T/A
Looks like the AutoProm is ready for Prime-Time.
Now taking orders...
Beta testing has been very positive, so rather than drag it out to the end of time, here ya go:
www.moates.net
Should be able to ship the next batch of units to customers by 01/15. More a week or two thereafter.
Quick synopsis on the beta testing results:
- Tested on 1227165, 1227730, 8747, 93 LT1, EEC-IV, etc. All cases solid stability. Need to test on wider array of devices, but all indications are positive so far.
- On the fly tuning works great, compatible with TunerPro RT and TunerCat RT. No problems or issues.
- Works as a standard ALDL cable, compatible with Moates software, Datamaster, WinALDL. Both 8192 and 160 baud. Seems to work real good.
- Has a special 'simultaneous' mode in TunerPro RT where you can log 8192 data, plot it up, and make BIN changes on the fly for immediate feedback. Works fine in all cases so far.
- Chip programming works like a dream on AT29C256 and AM29F040.
- Serial PC communications / software stability great on Win98/ME/XP/Etc. Don't know about Win95.
- Bootloading for firmware updates works without a hitch. Updates can be sent via web and you can upload them through TunerPro software.
- Three-channel 10-bit analog data acquisition is VERY fast (500+Hz) and works great. Should be able to pull off sampling up to 8kHz on this thing. While overkill, hey, maybe it can be an oscilloscope too? Anyways, you can use it for WideBand input or whatever, and log it simultaneously with other ALDL data or what have you, and make changes on the fly at the same time.
Also, there's a post over at moates.net with respect to the beta testing progress if you want to check it out.
Have fun!
-Craig
Old Jan 4, 2004 | 11:27 PM
  #188
Bluevette85's Avatar
Car: 85 Corvette
Engine: 355 Superram
Transmission: 700R4 Transgo Shift Kit
Can't wait to try it if the weather allows. My order has been placed. Logging the wideband at the same time will be great!
Old Jan 5, 2004 | 09:33 AM
  #189
11sORbust's Avatar
Old Jan 5, 2004 | 01:17 PM
  #190
jeepguy553's Avatar
Car: 1980 Jeep CJ7
Craig, you will have mail in a minute or two. My order is going in now!
Old Jan 6, 2004 | 05:30 PM
  #191
funstick's Avatar
i got one. i use it. and no craig cant have it back. he will he to fight me to the death. This thing is the **** !!!!!!
Old Jan 6, 2004 | 08:08 PM
  #192
jeepguy553's Avatar
Car: 1980 Jeep CJ7
I'll have one too shortly...then I'll be able to show all those in JeepLand what a REAL Jeep engine can do....heh heh heh...this is gonna be cool...
Old Jan 8, 2004 | 01:13 PM
  #193
Car: 87 T/A
Looks like everything presently scheduled for the 01/15/03 shipment is definitely spoken for (ie. paid for) at this point. Next round of shipments will be two weeks thereafter.
Additional firmware and software development continue (of course!). Feature creep continues to build momentum. What's next? Think about it. I guess this'll end up being like a "Swiss Army Knife for DIY Tuning".
Old Jan 8, 2004 | 01:37 PM
  #194
Mangus's Avatar
Transmission: T5WC
Craig keeps crackin' the whip man. I'm not sleeping, my wife doesn't remember what I look like. I'm down to 85 lbs (which makes my car even faster, btw). Is this thing ever gonna be finished?
Nope.
Old Jan 8, 2004 | 08:33 PM
  #195
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Nope.
We hope not!
We do want you to get some sleep though, and some time with the wife..... And also, you need to take some time to eat!
Old Jan 8, 2004 | 09:05 PM
  #196
jeepguy553's Avatar
Car: 1980 Jeep CJ7
Wife...??? I think I have one of those. I haven't seen her in a while, though. The Jeep takes up all of my time...at least that's what she says in her emails to me...
What is this word "eat"? How does one do this?
Old Jan 13, 2004 | 02:49 AM
  #197
nape's Avatar
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
In your case, I'd say "quickly and with dirty hands".
Hope you enjoy half my paycheck, Craig. Get crackin' on making more
Now I need to find a laptop...
Old Jan 16, 2004 | 04:14 AM
  #198
jamesbob02's Avatar
Car: 92 Z28
Engine: 357 TPI (L98)
Craig and Mark,
Any progress? Although the product is being released, I'm getting the impression that there are still a lot of kinks to work out, judging by the Autoprom thread in the Moates.net forums.
I'm hesitant because I'm not very good at this kind of stuff and am hoping that the experts get it all worked out and streamlined before I jump in. Do you forsee any necessary hardware updates, as in "oh, I didn't notice that...I need to do this here in the hardware to correct it....", or is it safe to go ahead and buy and the kinks are all on the software/firmware side?
BTW, if I'm wrong about these "kinks", be sure and let me know! I'd certainly rather hear that than be right lol.
Great work, guys.
Old Jan 16, 2004 | 05:26 AM
  #199
Car: 87 T/A
Looks like all the kinks are ironed out. As with most things, people get quiet when things are working well
I just finished shaking down the first round of 'sold' units last night, and they all came through with flying colors. They'll be boxed up and sent out on Monday via 2-day FedEx.
Next round of 9 units should be ready by 02/01.
Old Jan 16, 2004 | 08:22 AM
  #200
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
so these things do everything right? I dont need a programmer eraser or anything of the sort just this. i'll have to save up for it its a little steep on my budget. everything is. So i need this and an adapter correct to make it work on my 730 ecm
