what knock sensor would you use on a 400SBC?
Old Sep 26, 2003 | 12:16 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
what knock sensor would you use on a 400SBC? or do i have to just totally eliminate that feature and bypass the knock sensor?
Old Sep 26, 2003 | 07:11 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: what knock sensor would you use on a 400SBC?
If you leave a couple degrees room in the calibration, then most any v8 one compatible with your ecm is fine.
Some folks use them as a take it to the edge and run the max timing possible devise, and some just use it to protect things in case of a bad tank of gas.
Other then when the engine makes noises that can't be filtered out, I'd say run it.
Old Sep 26, 2003 | 12:30 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Re: Re: what knock sensor would you use on a 400SBC?
i want it mostly for the protection aspect... if i get one bad tank of gas on a road trip, id rather have it pull timing and protect the motor then have to get out and adjust the distrib....
now when you go from the 305 to the 350, i was told you HAVE to change it..the reasons why were unclear, but it was infered to me that detonation in a 350 was at a diff frequency then on a 305, so a diff knock sensor was in order to detect it..
does this mean i need one made for my 400? or will the 350 one (or even the 305 one) work?
Old Sep 26, 2003 | 01:14 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Re: Re: what knock sensor would you use on a 400SBC?
At one time I'd tried all the replacement K/S that Standard Ignition listed for a SBC. And I think there was a difference of about 3d between the lot. This was on an LG4, converted to TBI and a C3 ecm. While they do vary some, if it's just as a fail safe then I don't see a big problem, with being just being close. Least from what I've found.
YMMV
L98GTA87
Oct 19, 2015 10:43 PM
cking99
Sep 22, 2015 11:33 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
