383 '7747 starter bin ??
Old Oct 13, 2003 | 03:10 AM
ben73's Avatar
Hi Guys,
I'm about to build a 383 with AFR195's and a hyd. roller around 220*@.050". It will be run with a TBI 7747 ecm. Does anyone have a .bin for a motor similar to this that I can use just to start it up 1st time so I can be in the ballpark??
Thanks,
Ben.
Old Oct 13, 2003 | 02:52 PM
Ronny's Avatar
Ben, I assume you are running the XRam? One benefit of runing a 383 is it will increase the velocity through those large runners and large TB reducing the lack of atomization inherent and subsequent puddling i feel is an issue. I would think using the stock bin with an adjustment of the BPW would get you close. You could enrichen globally the #1 tables and take it easy at first with constant datalogging. should not take too long to get a feel where you are off. good luck...
Old Oct 14, 2003 | 01:01 AM
ben73's Avatar
Hi Ronny,
Yes I will be running an X-Ram and 2" TB's..
You are probably correct about just making a global change and going from there.
Thanks,
Ben.
3rd gen money
Oct 11, 2019 09:57 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
