Detuning Injectors?
Old Oct 14, 2003 | 04:38 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Detuning Injectors?
Lets say our car is a stock 91 SD 305 TPI and i burn my own proms. Lets pretend i just found a set of 24# injectors on ebay for $75. Can i install the 24# injectors and detune the injectors so they dont flow so much until i can upgrade my motor?
Old Oct 14, 2003 | 07:07 PM
BIG_MODS's Avatar
Car: 87 IROC
Engine: 5.3L
Transmission: Jerico
Axle/Gears: Aluminum 8.6 w/ T2R
Yes, you can "detune" the injectors. All that you have to do is change the injector constant in your chip. You'll want to do that with or without the engine upgrade.
Old Oct 14, 2003 | 07:52 PM
kevinc's Avatar
Car: 1982 Z28
Re: Detuning Injectors?
It's not "our" car, I'd pedal a bike before I'd drive a 305 again. But since we're talking theoretical...
Let's <b>pretend</b> you have a chip burner.
Let's <b>say</b> you have tuning software like Tunercat or whatever.
Let's <b>imagine</b> you punch in the actual flow rate of the theoretical injectors you have just found.
Let's <b>dream</b> that you burned that to a chip.
Let's <b>fantasize</b> that you installed that chip into your ECM...
Theoretically, it should run just fine.
Old Oct 15, 2003 | 01:07 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
Hypothetically, I am ROTFLMAO......
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
