Hack Articles?
Old Oct 22, 2003 | 01:35 AM
jonarotz's Avatar
Car: 91 Z28
Hack Articles?
Is there anywhere that can show me how to use a hack to maybe create new ECU items? Or anywhere that explains how to change or edit ECUs? This area has always been out of reach for me and I would just like to learn more.
Old Oct 22, 2003 | 03:08 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Hack Articles?
Have you tried opening the .ecu file with a word processing editor?.
ie open word pad, and then open file, select your .ecu and look at it. If it appears in normal text then have at it.
I don't use .ecu stuff, so this might be wrong, it's just since no one else took a stab at it, I'm suggesting what works on some other stuff.
HTH
Old Oct 22, 2003 | 03:14 PM
funstick's Avatar
you can create edit maipulate the ECU files with notepad actually. the hardest part is figuring out the hex to engineering unit converions. thats the trikest part of it all. other then that its not so bad.
Old Oct 22, 2003 | 03:42 PM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
Take a matching ecu and open it in wordpad. Then take that matching hack and open it in acrobat since thats usually the format. Every item in the ecu will have a hex location on it. If you do a search through the hack you should be able to match the exact hex and what it does and its exact calculation from hex to real world numbers.
Old Oct 22, 2003 | 09:53 PM
JohnL's Avatar
You don't need Wordpad if you are using Mangus' TunerPro- it's got a built in ECU editor.
There's an old article by Grumpy at ECM Guy's site- click here, and you can see something about how the hex numbers relate and PROM algorithms work out. You click on "Guest Expert- Bruce's page" It may be too technical for what you want, but there is plenty of meat in it.
I've got into trouble using a word processor to edit an ECU file- you'll soon see if you've added problem code with yours though (I think Notepad works on small ECU's?). As I recall, Tunerpro ECU's end up a lot bigger than standard because of the comment capability in the Tunerpro editor.
Check with Mangus and you'll get better than my shallow understanding.
John
Old Oct 23, 2003 | 08:33 AM
jonarotz's Avatar
Car: 91 Z28
Thanks guys, That helped me out a lot. I just needed a little direction. I still have some to learn but at least now I have a better understanding.
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
apie2546
Oct 16, 2016 02:24 PM
2012sergen11
Oct 13, 2015 07:38 PM
z28joe2
Sep 28, 2015 05:54 PM
Street Lethal
Sep 7, 2015 01:09 PM
