computer swap??Auto,L98 to T-5,LB9
Old Oct 25, 2003 | 02:51 PM
killerIROC's Avatar
I have an 88 IROC, auto, L98. I want to put the L98 in a 5speed 305 z28, between 1990-1992. What exactly I'm i going to have to do with the computer since the 350 computer is for an auto and the 305 computer is for the 305? Is there any way around a custom chip? And if i use the 305 chip on the 350, will it run crapping?
Old Oct 25, 2003 | 04:22 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Re: computer swap??Auto,L98 to T-5,LB9
First you have two completly different ECM's. The 88 is a MAF 165 ECM, the 90-92 is a MAP (SD) 730 ECM.
Either can be used with either engine, just match the bin in the Eprom (the chip inside the ECM) with bin from a 5 speed 305. (which the 730 should already be). Since their are no stock 350 with 5 speed bins, you have to use a 305 based calibration and work from there.
Since I take you are going to a 90- 92 Z28, using the 730 would be the way to go, since the wiring is different between a 730 and 165.
Please read Traxion's guide to programming in the sticky's above.
cheers, BW
gta90
Sep 15, 2015 04:00 PM
E Rod
Aug 28, 2015 05:17 AM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
matthew911
Aug 12, 2015 09:38 AM
