Options not avail in 32 or 32b bins
Old Oct 26, 2003 | 01:04 PM
eric305TPI's Avatar
Car: 82 ElCamino, looking for a 3rd gen
Engine: 305 TPI(427SB in progress) 730 $8D
Transmission: THM350 (Getting a 4L80E soon)
Axle/Gears: 10 Bolt w/ 2.43 gears :(
What I was wondering is if the DFCO and Decel Enleanment constants are able to be used in the $32 or $32b bins. They are there in my $6e bin.
Old Oct 26, 2003 | 01:08 PM
scorp508's Avatar
Car: Corvettes
Engine: Modified L98 & LT5
Transmission: DN 4+3 & ZF6
Axle/Gears: 3.07 & 4.10
I have no Decel Enleanment constants or tables in Tunercat for my $32b BINs. Is there such a thing? I've got Accel Enrichment constants.
Old Oct 26, 2003 | 01:49 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Options not avail in 32 or 32b bins
Yes they are usable in $32/$32B.
Many of the parameters are not in the mask definition files (TDF/ECU. . .). they can be added manually or if using TunerCAT they will add them and send a new TDF file.
The BUA hac shows a lot of what is available to the tuner ($32 mask).
RBob.
Old Oct 26, 2003 | 09:20 PM
scorp508's Avatar
Car: Corvettes
Why doesn't TC just put all the available constants/etc in there to begin with?
Old Oct 26, 2003 | 10:08 PM
Morley's Avatar
Now there's a novel idea.
Old Oct 27, 2003 | 03:00 AM
Mechanic's Avatar
Probably because the drop down menu system they use to navigate the binary with would be [sarcasm] just a bit awkward [/sarcasm] when trying to display over 300 constants. Not unlike adding 300 links to your browsers favorites in a single folder.
A "complete" 32 kb binary file definition can easily have over 800 constants.
GMPCM's DF.pcm definition file is a good example of a complete 32 kb binary definition, as it has over 1000 items defined. A bit larger definition than the 898 item $A1 that we enclose with the Evaluation Edition of GMPCM, since it has the 4T60 Electronic trans control infomation for the 16149396. The Evaluation Edition does well to illustrate just how fast and easy it is to navigate to a specific item of interest, even with the large amount of items that a complete definition entails.
seiplentz
Aug 19, 2019 06:02 PM
PurelyPMD
May 5, 2016 04:57 PM
david068513
Sep 18, 2015 10:36 AM
IROCZDAVE (88-L98)
Sep 17, 2015 07:43 AM
83 Crossfire TA
Sep 8, 2015 12:06 PM
