Scanning a SD 3.1 setup?
Old Oct 26, 2003 | 09:26 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
What are you guys using to scan the 3.1 '730 ecu?
Win ALDL doesn't work? There's got to be someone out there scanning a V6 '730!
Old Oct 27, 2003 | 06:50 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
A modified version of Craig's scanner (Moates) is all that I know of. There were a couple of people working on it then they all got quiet. All that needs to be done is to change the packet header values.
Doesn't seem to be too much work for someone to let everyone else use it.
RBob.
Old Oct 27, 2003 | 01:39 PM
Doward's Avatar
Modified version? Anyone on here have on, or know where to get one?
What exactly is it, that needs modifying in the packet header values?
Old Oct 27, 2003 | 04:41 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Here are the packets that are used for mode 1 communication with the 3.1l ECM (mask $88):
Chatter packet:
F0 55 BB
Data Request packet:
F0 56 01 B9
Data Packet:
F0 95 01 00 D0 02 00 00 00 40 40 20 00 00 08 00
00 00 00 00 00 65 00 00 80 00 00 58 0A 5E FA F8
E1 77 00 00 00 11 01 00 00 00 00 40 0D 2E 23 00
00 FF 00 00 00 24 01 F4 20 00 83 00 04 2E 50 80
81 00 23
The chatter packet is sent by the ECM on a regular schedule. The request packet requests a single data packet. After which another request packet is sent. If the data request packets stop for more then 1.5 seconds (IIRC) then the chatter packets are again sent by the ECM.
Moates software handles all of that. Even the baud rate is the same at 8192.
A while ago I looked at his code and it appeared that only a couple of locations required changing.
RBob.
Old Oct 29, 2003 | 10:27 AM
Badas.sbird's Avatar
Car: 1988 GTA
Engine: 404ci LS2
Transmission: 700R4 Full Manual Reverse
Axle/Gears: 3.91 Australian 9 Bolt
OK..you are way over my head. So how do you do this in dumbass terms.
Old Oct 30, 2003 | 07:21 AM
Doward's Avatar
ALright, lemme shuffle this around. PM sent..
Old Oct 30, 2003 | 10:26 AM
Car: 1988 GTA
Engine: 404ci LS2
Any word guys...I am still stupid.
Old Oct 30, 2003 | 12:34 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Not easy to explain. Basically it is the serial communications protocol between a scan tool and the ECM. The packets I've shown are what the ECM sends out along with a data request packet that it recognizes.
In order to make use of this information you'll need to know a little programming, working with hex, checksumming, data communications, serial port setup and usage, and so on.
RBob.
Old Oct 30, 2003 | 02:33 PM
Car: 1988 GTA
Engine: 404ci LS2
So basically it is a lot of work to do this. And not something that can be iterated and copied. Better question yet ....has someone done this?
Old Oct 30, 2003 | 06:56 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Yes it is a lot of work, yes it can be copied, yes it has been done, need it for your business?
RBob.
Old Oct 31, 2003 | 10:33 AM
Car: 1988 GTA
Engine: 404ci LS2
Yeah bith I and a couple customers have some need for it.
Old Oct 31, 2003 | 12:03 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Well then i reckon you can pay someone to figure it out for you, then write it off as a business expense.
Old Oct 31, 2003 | 02:27 PM
Car: 1988 GTA
Engine: 404ci LS2
OK good idea. So who is up for making a little extra cash?
Old Oct 31, 2003 | 02:28 PM
Car: 1988 GTA
Engine: 404ci LS2
Good idea. So who needs a little extra cash?
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
dusterbd
Sep 29, 2015 08:40 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
Eric-86sc
Sep 28, 2015 11:37 AM
