Wide Band Questions
Old Oct 31, 2003 | 02:24 AM
eric305TPI's Avatar
Car: 82 ElCamino, looking for a 3rd gen
Engine: 305 TPI(427SB in progress) 730 $8D
Transmission: THM350 (Getting a 4L80E soon)
Axle/Gears: 10 Bolt w/ 2.43 gears :(
Wide Band Questions
I've got a couple of questions about wide band o2 sensors systems. 1st How does the DIY one at www.DIY-WB.com compare to the Innovate Motorsports unit. 2nd Where is the most desirable location for the sensor to be mounted.
Old Oct 31, 2003 | 08:06 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Wide Band Questions
Not really an easy comparison. One is an inexpensive device that gives great bang-for-the-buck. The other is a commercial unit. One big differnce is that the Innovate unit comes with a display. For me that is not required, I data log. Others feel it is a necessity. If so, then there are several display options available for the DIY-WB.
Many vehicles have been successfully tuned with the inexpensive DIY-WB. I have a couple of DIY-WB units and use them with no qualms.
RBob.
Old Oct 31, 2003 | 01:12 PM
AustinT's Avatar
Here is A link that Might help you
https://www.thirdgen.org/techbb2/sho...light=innovate
A group purchase just ended for the Innovate Wideband, but I wouldnt mind starting a new one if it would help you
Good luck
Old Oct 31, 2003 | 06:13 PM
eric305TPI's Avatar
I would like to be able to get the I.M. with the group discount so i'm in for it.
Also what about location of sensor.
Old Nov 2, 2003 | 04:52 PM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
I feel it is best to locate it just after the two down pipes meet.
It should be mounted in such a way that the sensor points down, so condensation doesn't collect on it.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Terrell351
Jun 13, 2021 01:13 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Zeek1041
Aug 21, 2015 08:45 PM
redmaroz
Aug 16, 2015 11:40 PM
